Toon App: solarPanel ---> solar data without hardware
Plumifrons
Re: Toon App: solarPanel ---> solar data without hardware
Post by Plumifrons »
I"ve tried to get the solar info from my home assistant, but I can't get it to work. What API key of HA do I needl? I tried the > 200 caracters (at least it felt that way) hex api key I bu to no avail...
Who can point me into the right direction? The readme.md doesn't help me...
michel30
Post by michel30 »
could it be that Enphase has a problem?
Since x hours today I don't see it on Toon and also not in my homeassistant.
It looks like it stopped working.
When I login on my Enphase I see
Production from micro-omvormer
3.82 kW 07 Jul, 2023 12:57 PM
So the Enphase works, but not on Toon and Homeassistant.
07-07-23 16:40 ( edit note ).
I checked some other forums and it looks like that Enphase upgraded all firmwares to version : D7.6.175 and on this firmware it goes wrong.
New security or something.
Many users in homeassistant has the same issue, it does not work.
michel30
Post by michel30 »
The app works now in on my Toon :D .
I had to choose D7 enphase and not my enphase1.
I did not know that there was allready a fix in this app :lol:
For users who cannot get this to work in homeassistant or Toon you need a Token:
Here you can create a token for your enphase
https://entrez.enphaseenergy.com/login
For Enphase is a new way to login etc.
In Homeassistant I have it final working, I had also download a new app.
First I need to add a token:
https://entrez.enphaseenergy.com/entrez_tokens
Copy the token and go to your local enphase and add the token in.
What I could read this should be done every year :-( ..
In my home assistant I add it in on the following way:
-Host (I found that on my router - it's the IP adress of your Enphase thing)
Username - it's an email adress. It's the one you use for the app
Password - it's the password for the app
Serial Number (Yeah... Had to go to the app under system, then "devices" (my thing is in dutch, it's the last option), then Gateway, and the first number after SN is your serial number
Clicked on "Use Enlighten"
Voilà!
I see it back in homeassistant.
Hopefully this will help to get the app back in Toon...
michel30
Post by michel30 »
@oepi-loepi
Hopefully you can fix this solar app.
The problem is with the latest software from enphase D7.6.175.
Since lastweek it does not work correct anymore on the Toon.
Enphase changed someting, and my enphase one does not connect ( because not you need a username and password ).
I have selected now enphase D7 in here you can fill in your username and password.
But what I see now on my toon, it says 55 watt but in my homeassistant it says 712 watt so hopefully the APP builder can fix this problem with the new setup from Enphase.
Thanks.
oepi-loepi
Post by oepi-loepi »
can you try enphase-T ?
Geef de naam en wachtwoord van de https://enlighten.enphaseenergy.com site en de URL van jouw envoy, bijvoorbeeld 192.168.10.3
michel30
Post by michel30 »
When I used enphase-T nothing happend.
Als ik die gebruik zie ik geen verbruik hoeveel die op dit moment aan het produceren is.
Wanneer ik de D7 gebruik wel, maar dan klopt het niet is dan veelste laag.
Voorheen heeft het altijd gewerkt op Enphase 1 tot dat enphase nieuwe software heeft gepusht en iedereen nu D7.6.175 heeft.
Je moet nu een een naam en wachtwoord van de https://enlighten.enphaseenergy.com site gebruiken.
Als ik D7 kies dan kan je dan invoeren dan klopt het aantal watt niet wat die op dat moment produceerd.
Als ik enphase-T kies dan blijft die op nul watt staan.
Als ik de oude Enphase kiest blijft die ook op nul watt staan, ( voorheen niet tot software D7.6.175 )
Bij de oude Enphase kan je ook geen gebruiken en wachtwoord opgeven.
Ik weet niet als dat helpt wanneer dat wel gaat als die het dan misschien wel weer werkt.
oepi-loepi
De oude enphaseplugin werkt niet met versie d7.
Het beste en meest snelle zou de enphase-t versie moeten zijn die ook gewerkt heeft. Wellicht is er weer iets veranderd bij enphase in een update.
Enige manier om te testen voor mij is door het krijgen van
Inlognaam en wachtwoord in het enphase portal
Toegang tot de lokale omvormer middels een port forward
Zelf heb ik geen enphase dus als iemand mij daar (weer) bij kan helpen dan zou dat mooi zijn. Gegevens kunnen via een pm.
Micha_123
Post by Micha_123 »
sience the new domoticz update yesterday, domoticz is using an new API.
[WebServer] Deprecated RType (devices) for API request. Handled via fallback (getdevices), please use correct API Command! (192.168.102.64)
that is also showing in the domoticz log.
domoticz has changed the API. for now there is an fallback and the plugin is working as wel.
i use solar panel and toon water (both reads the data from domoticz) and the ip adress domoticz is showing is the one from my toon. so one from the both plugins couse the message in the logs.
oepi-loepi
Thank, i have read it. Problem now is tat most users have not updated their donoticz yet and some will never do. So i have to double the call based on output.
I wonder what the output will be when the old api fails,
Micha_123
Post by Micha_123 »
Maybe if it is possible, make an option in config
Use new domoticz api
If it wil be possible.
oepi-loepi
I have made a second plugin (Domoticz (2023.2>)). Can you check if this works?
Micha_123
Post by Micha_123 »
I wil check if I'm @ home
michel30
Post by michel30 »
Xavier wrote: Wed Apr 19, 2023 1:24 pm Enphase zonnepanelen systeem bestaat uit een aantal onderdelen:
1. Zonnepanelen uiteraard
2. Micro omvormers die onder de zonnepanelen zitten
3. Q-relais (1fase of 3-fase)
4. Enphase Envoy gateway (2 modellen beschikbaar: Enphase Envoy S of Envoy Metered)
In de Enlighten app van Envoy kun je naar Menu gaan, dan naar systeem en dan vervolgens naar apparaten.
Als het goed is zie je groepen apparaten staan namelijk: Gateway en Microinverters.
Kies voor Gateway, je ziet nu welke type gateway je hebt (metered of de S) en daar staat ook de firmware versie (de nieuwste op dit moment is de D7.0.88 firmware).
In het geval van de D7 firmware kies je in de Solarpanel app in de toon voor Enphase-T.
Hi Xavier,
Question does your Enpahse still work with your Toon?
I have 1fase and my gateway model is Enphase Envoy S with firmware D7.6.175
Joskep
Post by Joskep »
Lees aandachtig mee :-)
Ben overgestapt van Domoticz naar Home Assistant en heb zowel SMA als Enphase...
Lukt mij helaas ook niet (meer) de data op de Toon te zien.
Bij Domoticz was het een kwestie van verwijzen naar de juiste IDX-en, maar zo makkelijk lijkt het binnen HomeAssistent (nog?!) niet te gaan.
Edit: Via het test tegeltje getest op IP-adres en wachtwoord van de SMA, die geeft netje resultaat.
Bij mij zit het hem dus ook even meer ri de Enphase
EDIT 2: Gelukt!
In de Toon-app HomeAssistant kan je kiezen voor sensoren, daar moet de unieke naam/code van de zonnepanelen ingevoerd worden MINUS "sensor.".
Nu heb ik beide sets zichtbaar, wel in een heel erg klein lettertype maar goed. Iets is beter dan niets, scheelt een hoop gedoe met API-keys e.d.
Micha_123
Post by Micha_123 »
oepi-loepi wrote: Sun Jul 30, 2023 11:10 am I have made a second plugin (Domoticz (2023.2>)). Can you check if this works?
now im @home, and yes it is working.
but the toonwater app does the same in log. :D
but solarpanel with the setting domoticz 2023.2 is working fine.
