Max CV water setpoint
JoHe
Post by JoHe »
I need some help on my OpenTherm settings.
I have running Domoticz on a RaspberryPi 4
Attached an OpenTherm gateway (by LAN) and configured in Domoticz.
It returns 26 devices.
one of them is Max CV water setpoint and this is the one I want to control ie change when needed.
My project is to set the temperature higher when heating is wanted in my bathroom.
Standard it's set to 45 degrees due to the fact that my whole home is equipped with floor heating
except the bathroom. I have a temperature sensor in the bathroom so I know when to start heating.
At that point I close all valves to the floor heating and open the valve to the bathroom.
In order to get a nice temperature in the bathroom I need to increase the water temperature to a
minimum of 60 degrees. However I can't change that value. I can change it on the CV itself, so
it is possible.
I've made a screenshot of my devices however can't find any option to upload it, therefore
below in text format.
need some help on getting this solved.
below devices:
Idx Hardware ID Unit Naam Type SubType Data
516 OpenTherm 0001 1 Control Setpoint Temp LaCrosse TX3 10.0 C
517 OpenTherm 0000005 0 Room Setpoint Thermostat SetPoint 20.0
518 OpenTherm 0008 8 Room Temperature Temp LaCrosse TX3 21.6 C
519 OpenTherm 0009 9 Boiler Water Temperature Temp LaCrosse TX3 52.8 C
520 OpenTherm 000A 10 DHW Temperature Temp LaCrosse TX3 0.0 C
521 OpenTherm 000B 11 Outside Temperature Temp LaCrosse TX3 13.5 C
522 OpenTherm 000C 12 Return Water Temperature Temp LaCrosse TX3 53.1 C
523 OpenTherm 00000003 1 Maximum Relative Modulation Level General Percentage 100%
524 OpenTherm 0000010 0 Max CV Water Setpoint Thermostat SetPoint 45.0
525 OpenTherm 00000006 1 Relative modulation level General Percentage 0%
512 OpenTherm 0000071 1 CV Flame Lighting 2 AC Off
511 OpenTherm 0000070 1 DHW_active Lighting 2 AC Off
504 OpenTherm 0000065 1 CH_enabled Lighting 2 AC Off
510 OpenTherm 000006F 1 CH_active Lighting 2 AC Off
505 OpenTherm 0000066 1 DHW_enabled Lighting 2 AC On
500 OpenTherm 0000060 1 GPIOAPulledToGround Lighting 2 AC Off
501 OpenTherm 0000061 1 GPIOBPulledToGround Lighting 2 AC Off
502 OpenTherm 0000062 1 GPIOAStatusIsHigh Lighting 2 AC Off
503 OpenTherm 0000063 1 GPIOBStatusIsHigh Lighting 2 AC Off
506 OpenTherm 0000067 1 Cooling_enable Lighting 2 AC Off
507 OpenTherm 0000068 1 OTC_active Lighting 2 AC Off
508 OpenTherm 0000069 1 CH2_enabled Lighting 2 AC Off
509 OpenTherm 000006E 1 Fault_indication Lighting 2 AC Off
513 OpenTherm 0000072 1 Cooling_Mode_Active Lighting 2 AC Off
514 OpenTherm 0000073 1 CH2_Active Lighting 2 AC Off
515 OpenTherm 0000074 1 DiagnosticEvent Lighting 2 AC Off
