Only have "Afvalwijzer" and "Buienradar" app.
Don't use the Powermeter etc. so is it possible to disable the services:
- {hdrv_zwave} HCBv2
{happ_smartplug} HCBv2
{happ_pwrusage} HCBv2
{hdrv_p1} HCBv2
And if so, what is the best way to do this?
remove the 0-sized files from /qmf/etc/start.d/jnieuw wrote:Think it gets an OOM (out of memory).
{hdrv_p1} HCBv2
happ_eventmgr happ_pwrusage happ_smartplug happ_usermsg hcb_config hcb_rrd hdrv_hue hdrv_sensory lighttpdMartello wrote:Hallo
I accidently deleted al files out of this folder. Can somebody tell me the names of the files inside this folder? /qmf/etc/start.d
Thanks Chris
Thank you @TheHogNL, I disabled the services, including hcb_rrd and Toon is much more responsive now.TheHogNL wrote:remove the 0-sized files from /qmf/etc/start.d/jnieuw wrote:Think it gets an OOM (out of memory).
{hdrv_p1} HCBv2
if you need to start them just create 0-size file with the same name again (using touch or something)
You can safely remove those log but you can't stop those lines. Those are because we are blocking those call to eneco but the software keeps trying so that's why you see those log lines.jnieuw wrote:Thank you @TheHogNL, I disabled the services, including hcb_rrd and Toon is much more responsive now.TheHogNL wrote:remove the 0-sized files from /qmf/etc/start.d/jnieuw wrote:Think it gets an OOM (out of memory).
{hdrv_p1} HCBv2
Can I ask what each of these services are doing (hcb_bxtproxy, hcb_log, happ_hvac, happ_scsync) and if they can be disabled?
-I see a lot of log files in /mnt/data/qmf/log, they contain old log data as well. Can I remove these without problems?
-The 01_GENERAL.log.json contains lots of Problem posting report to %s; error(%s) discarding",["http://feed.hae.int:31080/benchmark/friendRequest... etc. is there a way to disable these reports?
-And the 99_DEBUG.log.json contains lots of "Triggering HardRestarts for all OpenVPN instances (%s)",["iterations % 60: ST_INTERNET tunnel conn timeout"]],, again, is there a way to disable these?
Just tried something myself. Scsync needs to be running as it provides information how the toon should start (which services enabled etc). At least, in my toon1 test the GUI didn't start without scsync running.jnieuw wrote:Thanks for the reply.
I will turn them off and post the results here (after a week or so). Memory is almost double and Toon1 is still responsive since I turned the previous services off...
I came to the same conclusion. Only services I've running now are:TheHogNL wrote:Just tried something myself. Scsync needs to be running as it provides information how the toon should start (which services enabled etc). At least, in my toon1 test the GUI didn't start without scsync running.jnieuw wrote:Thanks for the reply.
Laat eens een 'top -b -n 1' output zien hierjnieuw wrote:Uptime: 29 days
And there is definitely a memory leak somewhere:
Mem: 123340K used, 2856K free, 256K shrd, 0K buff, 34752K cached
CPU: 4.3% usr 5.1% sys 0.0% nic 90.3% idle 0.0% io 0.0% irq 0.1% sirq
Load average: 0.43 0.25 0.17 1/99 29178
I've lost 9000K memory somewhere doing nothing.
Any idea how to find the cause?
