Just rooted and updated to 5.49.7
oliviermls
Post by oliviermls »
I just successfully rooted my toon and soone after it offered me to download 5.49.7 firmware. I just did that and now I'm worndering if I updated it with the eneco's firmware or TSC's firmware.... I no longer see the little basket.
Have I just undone the rooting!? How do I check? How do I get it back??
Thanks
Re: Just rooted and updated to 5.49.7
Post by TheHogNL »
An update is always the official firmware. There is no TSC firmware.
The only thing is that after a official update the TSC script runs to 'fix' the rooting again.
You can force that with the '-f' option after the update script.
So go download it (from https://github.com/ToonSoftwareCollective/update-rooted) and run 'update-rooted.sh -f'
oliviermls
thanks for such a quick reply! Much appreciated.
Newbie here, how do I "download the script towards your Toon. The easiest way is just to use curl from your Toon"? Is there a command line option on Toon? How do I access it? Or where exactly do I run this?
I did the initial rooting via a linux kalil usb, by the way
Thanks a lot
oliviermls
No need. I figured out I had to use putty!
many thanks. All good now :))
oepi-loepi
Post by oepi-loepi »
Instead of using putty. You can also use the windows command line (as from windows10):
ssh root@ipoftoon
Return to “Toon Firmware”
