[SOLVED] Issue upgrading Toon2 from 5.33.9
Rudolf
Post by Rudolf »
Thanks to the PSA somewhere else in this forum I was triggered to attempt an upgrade of my Toon2.
(I was still happy with 5.33.9, because later versions may remove some OpenTherm-stats)
But it doesn't work, and I was unable to find another thread with the same issue.
The update starts, but doesn't download (stuck at 0%), and end with an error that tells me to check the logs, so I did.
Here's the log.
Version: 4.61 - TheHogNL - 12-04-2022
Unattended mode
You are currently running version 5.33.9 on a nxt with flavour uni
Available versions: 1.9.10 2.1.0 2.2.24 2.3.17 2.3.29 2.3.36 2.4.7 2.4.12 2.5.11 2.5.14 2.5.18 2.6.24 2.6.33 2.8.16 2.8.21 2.8.27 2.9.15 2.9.26 2.10.15 3.0.29 3.0.32 3.1.22 3.2.14 3.2.18 3.2.21 3.3.8 3.4.2 3.4.4 3.5.4 3.6.3 3.7.8 3.7.9 4.3.20 4.4.21 4.7.23 4.8.25 4.9.23 4.9.124 4.10.6 4.10.9 4.11.6 4.12.0 4.13.6 4.13.7 4.15
Unattended selected version 5.49.16
Alright, I will try to upgrade to 5.49.16
Could not enable VPN in a normal reasonable time!
DEBUG information:
default via 192.168.1.1 dev wlan0 metric 10
192.168.1.0/24 dev wlan0 scope link src 192.168.1.115
# <persistent /etc/hosts content can be added to /etc/hosts.template file>
127.0.0.1 localhost.localdomain localhost qb-659916001600-1801A016RL
172.26.112.1 feed.hae.int feed
127.0.0.1 ping.quby.nl
END DEBUG information
So the VPN is the issue.
I tried to run that manually, but no dice.
I tried it once more on a system that allowed to copy and paste the logs and now it seems to work fine...
Thu Apr 14 20:21:16 2022 OpenVPN 2.3.6 arm-angelica-linux-gnueabi [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Oct 18 2017
Thu Apr 14 20:21:16 2022 library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.09
Thu Apr 14 20:21:16 2022 WARNING: file '/etc/openvpn/certs/device.key' is group or others accessible
Thu Apr 14 20:21:16 2022 Control Channel Authentication: using '/etc/openvpn/certs/ta-ene.key' as a OpenVPN static key file
Thu Apr 14 20:21:21 2022 Attempting to establish TCP connection with [AF_INET]108.128.193.17:443 [nonblock]
Thu Apr 14 20:21:23 2022 TCP connection established with [AF_INET]108.128.193.17:443
Thu Apr 14 20:21:23 2022 TCPv4_CLIENT link local: [undef]
Thu Apr 14 20:21:23 2022 TCPv4_CLIENT link remote: [AF_INET]108.128.193.17:443
Thu Apr 14 20:21:26 2022 [VPN-Eneco] Peer Connection Initiated with [AF_INET]108.128.193.17:443
Thu Apr 14 20:21:29 2022 TUN/TAP device tap0 opened
Thu Apr 14 20:21:29 2022 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Thu Apr 14 20:21:29 2022 /sbin/ip link set dev tap0 up mtu 1500
Thu Apr 14 20:21:29 2022 /sbin/ip addr add dev tap0 172.26.198.165/20 broadcast 172.26.207.255
Thu Apr 14 20:21:29 2022 Initialization Sequence Completed
Perhaps the VPN is flaky (loadbalancer?) and doesn't work reliably.
I tried running update-rooted.sh from the shell and supplied the version 5.49.16, but it still fails on the VPN.
When it tries IP '52.48.246.167:443', it won't work.
Since IP '108.128.193.17' does work I hardcoded that into the /etc/openvpn/vpn_port.conf.
Now the script can connect to VPN properly and starts downloading files.
I started this post as an attempt to ask for help. But I'll post it anyway, perhaps it's useful for anybody else.
Re: [SOLVED] Issue upgrading Toon2 from 5.33.9
Eneco has some VPN servers active with the old keys and the other half with the new keys.
Therefore setting up the VPN sometimes fails (if you end up at the wrong server).
Simply retry the upgrade until you land at a correct server.
Rudolf
Post by Rudolf »
Nice to have an explanation.
Upgrade went smoothly, thanks for the support.
Return to “Toon Firmware”
