I have picked up my 'old' OTGW project again, with the intention to integrate it into HomeAssistant.
I flashed my NodoMCU with the latest 0.9.5 release, and the GUI is quite responsive when not connected to the OTGW board.
When connecting the nodoMCU to the OTGW board, the GUI seems to turn 'sluggish'. The information from the 'advanced' menu takes ~ 20 seconds to load/show. Is this something to worry about?
What I am looking for, is a procedure on how to update the PIC on the OTGW board, via the GUI. I cannot find anywhere how to do this.
The GUI shows in the left bottom corner that a new PIC version 5.4 is available.
I uploaded the 5.4 gateway.hex file to via the 'file explorer', but the PIC firmware shows both 4.3 and 5.4 version.
Thanks for any help, maybe a little manual needs to be written?
ps: there following does work (so the hardware seems OK):
$ nc -v 192.168.3.140 23
Connection to 192.168.3.140 port 23 [tcp/telnet] succeeded!
20:25:31.338542 ( 12056| 11584) sendMQTTupti( 144): Uptime seconds: 55419
20:25:44.878915 ( 12088| 11584) addOTWGcmdto(1239): CmdQueue: Adding cmd end of queue, slot [0]
20:25:44.884082 ( 10744| 10288) addOTWGcmdto(1242): CmdQueue: Insert queue in slot[0]:cmd[SC=22:25/3] (10)
20:25:44.885837 ( 10744| 10288) addOTWGcmdto(1262): CmdQueue: Next free queue slot: [1]
20:25:46.629873 ( 12008| 11304) handleOTGWqu(1278): CmdQueue: Queue slot [0] due
20:25:46.635236 ( 10664| 10008) sendOTGW (1368): Sending to Serial [SC=22:25/3] (10)
20:25:48.391583 ( 11928| 11304) checkOTGWcmd(1318): CmdQueue: Checking if command is in in queue [SC: 22:25/3] (11)
20:25:48.394054 ( 10584| 10008) checkOTGWcmd(1329): CmdQueue: Checking [SC]==>[0]:[SC=22:25/3] from queue
20:25:48.394947 ( 10584| 10008) checkOTGWcmd(1332): CmdQueue: Found cmd [SC]==>[0]:[SC=22:25/3]
20:25:48.395435 ( 10584| 10008) checkOTGWcmd(1335): CmdQueue: Found value [ 22:25/3]==>[0]:[SC=22:25/3]
20:25:48.395862 ( 10584| 10008) checkOTGWcmd(1336): CmdQueue: Remove from queue [0]:[SC=22:25/3] from queue
20:25:48.396296 ( 10584| 10008) checkOTGWcmd(1338): CmdQueue: Moving [1] => [0]
