Plugwise on Bwired
RDNZL
Plugwise on Bwired
Post by RDNZL »
Is it possible to write your own code to communicate with the devices, by using the dongle on linux?
I don't want to use windows software, since my server is linux based.
If you plug the dongle in a linux machine, what is the name of the device. Anyone know?
Ron.
Developing DomotiGa - Gambas powered Domotics.
Plugwise on Bwired
No Linux support yet, but they are planning!
However I think it will never be made possible to communicate directly to the USB dongle, at this moment Plugwise will not give it free.
The Plugwise Sofware has a sort of API function or you can use the small separate webserver which will do the communication. All is based on Windows for now.
RDNZL
Plugwise on Bwired
Post by RDNZL »
Hmm, I don't run a windows server, and running one just for plugwise is not well... wise...
Is someone willing to plug the dongle into their linux server to see what dmesg is telling?
Is plugwise looking for linux based field testers by any chance?
RDNZL
Plugwise on Bwired
Post by RDNZL »
What about the "stretch lite"? It communicates via tcp/ip with the software on another pc. Would be nice to talk/read from this device over the network.
Anyone has it?
RDNZL
Plugwise on Bwired
Post by RDNZL »
Hmmm... if they are using an EM250 like I found somewhere... these are interesting documents:
http://www.ember.com/pdf/120-5049-000_E ... gGuide.pdf
http://www.ember.com/pdf/120-0082-000_E ... asheet.pdf
Remove file name from end of url to find more pdf's...
Plugwise on Bwired
Right
That is what the data in the source software is telling me!
for example the Airpurifier consumes 4.16 watt
myozone
Plugwise on Bwired
Post by myozone »
it could be displaying to 0.01 of a Watt but increments in larger steps ? - just an idea
aeh
Plugwise on Bwired
Post by aeh »
Yesterday I bought the Plugwise startpakket.
Today they send me the box with goodies before they have the money on the bank. Very good service from Plugwise.
I can't wait to play with it.
bonza
Plugwise on Bwired
Post by bonza »
Hi Ron,
Just received my starters kit, it contains a classic usb -> serial convertor.
ftdi_sio 1-1.1:1.0: FTDI USB Serial Device converter detected
drivers/usb/serial/ftdi_sio.c: Detected FT232BM
usb 1-1.1: FTDI USB Serial Device converter now attached to ttyUSB3
Seems to communicate at 9600 baud.
RDNZL
Plugwise on Bwired
Post by RDNZL »
Start to think about buying a start kit too...
Ron.
aeh
Plugwise on Bwired
Post by aeh »
My startpakket arrived today. The installation took me less the 10 minutes. Everything works fine butt I have some questions:
- When I use the circle in the pantry most off the time I don't reach it with the usb device. The distance between the usb device and the pantry is about 10 meter with one wooden door in between. Is that normal. I thought this system works on a larger distance.
- For most of the devices in my house it isn't profitable. The cost of the circles are to expensive. Does anyone has tips for me.
Pieterpaul
Plugwise on Bwired
Post by Pieterpaul »
Do you know how to communicate with the device? I thought the protocol was closed and you can only use it with 'The Source'?
/PP
Plugwise on Bwired
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by aeh</i>
<br />Hello,
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I had the same experience, try to put the circle+ closer to the USB dongle, distance of the other circles (non +) can be further away.
Snelvuur
Plugwise on Bwired
Post by Snelvuur »
@aeh: i thought it was zigbee protocol, doesn't every 'plug' act as a repeater too? (http://en.wikipedia.org/wiki/ZigBee)
aeh
Plugwise on Bwired
Post by aeh »
Yes it does.
One nice feature is the web based part of the application.
It's a minimal feature. I like to enable and disable the circles on my PDA but the on an off buttons in the application doesn't work on a PDA. Has anyone a solution for this??????
Return to “Bwired Forum”
