Control warm water supply of central heating with heatpump boiler
Posted: Mon Oct 31, 2022 12:24 pm
I recently installed a 300l standalone heatpump boiler for my warm water supply. Although standalone, it is still connected to my central heating system via a diverter valve. So in one of those rare cases that the whole family decides to take a bath after each other, we won't run out of warm water...
Everything is working perfect and we don't use gas for warm water anymore. Only problem I have is when there's warm water demand, my central heating system is starting up for warm water supply because there's always a little bit of cold water left in the pipes before the diverter valve switches and bypasses the central heating system. Central heating is starting up, using a tiny bit of gas and shuts down again. I'm not worried of the gas, but I am worried about all those starts and quick stops will end up bad for my heating system. The diverter valve is placed as close as possible to the heatpump boiler by the way.
I'm looking for an OpenTherm solution to switch of the warm water supply of my central heating system when water in the heatpump boiler is >50°C.
My old heatpipe boiler (Itho Daalderop) had this option and was mounted between my room thermostat and the central heating system. Whenever the warmwater supply of the boiler was warm enough, the warm water supply of the central heating system automatically switched off.
Hope you guys can help out with a simple and 'set and forget' solution!
Thanks!
Thanks!
