OTGW FW5.6 HA Setpoint override reset
Posted: Mon Nov 28, 2022 11:31 am
with firmware 5.6 I experience different behaviour while using the setpoint override from Home Assiatnt. The setup is a Nest / Vaillant OT33 and I connect to the gateway through a D1MINI. While overriding the setpoint from HA it will initially work as expected but after about a minute after ignite the boiler will return to the thermostat setpoint. I my case I only override when the nest is idle (setpoint 10 degrees) and I override it currently with max setpoint (79 degrees) and min modulation (30%).
After reverting back to firmware 5.4 it works again as expected (keeping the setpoint override in place until setting the setpoint at 0 from HA).
Just to share my findings.
- Stephan
- Stephan
