hvxl wrote: Sat Dec 03, 2022 6:41 pm
EvoHome with R8810 OT Gateway should work. The OTmonitor log may provide clues.
The log is filled with:
18:50:13.393768 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:14.389960 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:15.387740 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:16.384372 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:17.380148 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:18.377639 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:19.376284 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
otdata.txt
;;;0;;;;;;;;;;;;20221203;18:51:00
18:48:33.764457 ðOpenTherm Gateway 6.3
18:48:33.767788 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:33.770403 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:33.772718 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:33.774991 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:33.777100 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:33.779133 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:33.800905 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:33.803567 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:33.805816 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:33.807881 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:34.691742 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:35.683732 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:36.686025 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:37.683074 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:38.679652 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:39.670269 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:40.673665 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:41.670007 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:42.659369 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:43.656113 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:44.653070 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:45.657235 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:46.655245 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:47.641753 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:48.645918 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:49.641564 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:50.632975 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:51.634776 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:52.625142 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:53.622308 T900E6400 Write-Data Maximum relative modulation level (MsgID=14): 100.00
18:48:54.622025 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:48:55.615094 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:48:56.614164 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:48:57.610343 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:48:58.606048 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:48:59.601580 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:00.597884 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:01.593542 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:02.597334 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:03.592954 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:04.582245 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:05.584546 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:06.578699 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:07.576369 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:08.568578 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:09.565035 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:10.561976 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:11.558265 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:12.554933 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:13.552026 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:14.548361 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:15.544783 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:16.541309 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:17.537627 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:18.534100 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:19.536752 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:20.527655 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:21.525076 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:22.526117 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:23.517449 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:24.520440 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:25.510329 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:26.511290 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:27.502299 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:28.500479 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:29.496461 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:30.499007 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:31.492657 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:32.486412 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:33.483021 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:34.481281 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:35.480054 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:36.472732 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:37.470257 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:38.471969 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:39.462261 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:40.458704 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:41.455245 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:42.452131 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:43.451407 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:44.445682 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:45.441827 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:46.439298 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:47.435970 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:48.431358 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:49.429638 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:50.426700 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:51.435698 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:52.433163 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:53.455827 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:54.452282 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:55.449180 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:56.446660 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:57.448338 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:58.443349 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:49:59.437191 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:00.438332 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:01.429919 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:02.426612 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:03.423112 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:04.422278 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:05.416200 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:06.412733 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:07.418543 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:08.406644 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:09.408252 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:10.405620 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:11.403334 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:12.396758 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:20.377441 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:21.367293 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:22.363643 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:23.368507 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:24.365707 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:25.364781 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:26.358310 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:27.355333 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:28.353456 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:29.357459 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:30.352713 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:31.350689 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:32.347194 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:33.343702 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:34.352357 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:35.341341 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:36.334322 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:37.335783 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:38.330014 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:39.323981 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:40.320515 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:41.318931 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:42.320205 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:43.310853 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:44.307503 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:45.308853 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:46.302092 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:47.303385 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:48.294250 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:49.291252 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:50.288593 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:51.284508 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:52.280663 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:53.277010 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:54.275788 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:55.270429 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:56.267050 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:57.264384 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:58.259558 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:50:59.256962 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:51:00.252742 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:51:01.250869 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:51:02.246284 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:51:03.242959 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:51:04.239320 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:51:05.235417 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:51:06.232119 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:51:07.229227 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:51:08.225434 T00030000 Read-Data Slave configuration (MsgID=3): 00000000 0
18:51:09.226646 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:10.218135 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:11.221708 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:12.215078 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:13.213817 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:14.204794 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:15.201721 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:16.202600 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:17.196274 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:18.190694 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:19.188201 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:20.184839 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:21.182416 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:22.179486 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:23.172840 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:24.169285 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:25.167233 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:26.163382 T00780000 Read-Data Burner operation hours (MsgID=120): 0
18:51:27.162655 T00780000 Read-Data Burner operation hours (MsgID=120): 0
