No SSH connnection
Pandabeer35
No SSH connnection
Post by Pandabeer35 »
I'm new and just rooted via procedure: https://github.com/ToonSoftwareCollective/Root-A-Toon - everything went well - at the end I saw maybe an error
creating backup of hosts...
FIXING: Downloading resources.rcc TSC mod for this version 5.22.16.
-- Updating custom app toonstore to release 5.1.3 ... DONE
EDITING: add disable power management wifi on Toon2
EDITING: add autobrightness feature on Toon2
EDITING: disabling Eneco subscription feature apps which are not working on rooted toons
EDITING: lighttpd so tsc/sensors is viewable via a browser
Finished fixing files!
mkstemp: No such file or directory
ssh: connect to host 192.168.4.5 port 22: Connection refused
Now I try to get SSH connection so I can make connection with Home Assistant (put a long token on Toon) but it's not possible to connect
Are there other possibilities to get connection via SSH or make the rooted Toon to work with SSH
Thank you for your reply!
Greetingz from Harderwijk
Pandabeer35
Re: No SSH connnection
Solved! Just run update once again - now SSH is enabled and everything is working! :D
Return to “Toon Rooting”
