screen on Toon with http rule
If you don't know where to post, post here.
marktn
Post by marktn »
I have a rooted Toon V2.
Is there a way to get the screen on, with a http rule?
Greets,
Mark
marktn
Re: screen on Toon
Post by marktn »
Nobody? :) Or is it not possible? :shock:
Mark
oepi-loepi
Re: screen on Toon with http rule
Post by oepi-loepi »
Not possible to set the screen itself with a http rule. You can set the thermostat to at home. But then you will interfere with the current thermostat state.
Return to “Toon miscellaneous”
