Can Firewire power a Ninja?
Posted: Mon Sep 15, 2008 4:37 pm
I have a Firewire camcorder mounted on a Ninja which has also got two power supplies (one for the camcorder, one for the Ninja).
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Typically a device can pull about 7 to 8 watts from the port; however, the voltage varies significantly from different devices. Voltage is specified as unregulated and should nominally be about 25 volts (range 24 to 30).<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
So today's question is... will the Firewire bus have enough power for the camera and to move the Ninja pan/tilt? We'll see [:p]
Steve
Steve
