Issue with Toonstore after Rooting Firmware 6.2.4
lucifermorningstar
Post by lucifermorningstar »
Dear gentlemen,
I wanted to inform you that I have successfully rooted my Toon with firmware 6.2.4. The rooting process appears to be successful, but unfortunately, the Toonstore is missing. In an attempt to resolve this issue, I executed the upgrade script with the -f option, but so far, the Toonstore remains unavailable.
What makes it even stranger is that I managed to get another Toon with firmware 6.0.9 working, even though this firmware version is also not listed in the supported versions.
I appreciate your assistance in advance!
Re: Issue with Toonstore after Rooting Firmware 6.2.4
check the output log of the upgrade script if there are issues with downloading the resourcefile for 6.2.4 or downloading the ToonStore app.
lucifermorningstar
Toonz wrote: Fri Nov 10, 2023 3:08 pm check the output log of the upgrade script if there are issues with downloading the resourcefile for 6.2.4 or downloading the ToonStore app.
Thanks for your response!
I have solved the issue by using the recovery method.
Recover to version 5.0.6. then login with SSH and upgrade it to the latest version.
Return to “Toon Rooting”
