If I switch to dim mode for a second it is bright, but than goes darker.
Is there a way to keep the brightness high also in dim mode?
I set brightness via settings to 100% for both.
I see the update-rooted.sh script has a editAutoBrightness function.
the sed instruction looks to be missing a 'g', but also after correcting that I see no difference.
$ diff -durN update-rooted.sh.orig update-rooted.sh
--- update-rooted.sh.orig 2023-12-28 04:07:25.946564782 +0100
+++ update-rooted.sh 2023-12-28 04:09:54.676517266 +0100
@@ -141,7 +141,7 @@
#set feature auto brightness on toon2 if not exists
if ! cat /qmf/config/config_happ_scsync.xml | tr -d '\040\011\012\015' | grep -q "<feature>displayAutoBrightness"
then
- sed -i 's/<\/features>/<feature>displayAutoBrightness<\/feature><\/features>/' /qmf/config/config_happ_scsync.xml
+ sed -i 's/<\/features>/<feature>displayAutoBrightness<\/feature><\/features>/g' /qmf/config/config_happ_scsync.xml
fi
