Install location of OTGW
Posted: Mon Jan 08, 2024 4:12 pm
I wondered where to exactly install the OTGW, given the following warning in the user manual:
Secondly, I have this connector that adds 24V to that two-wire line, see attachment.
Should I connect the OTGW between this connector and the boiler or this connector and the thermostat?
Thanks!
First of all, how do I verify the first point? I have a two-wire going from the boiler to a small connector with power (see below). And there is also a normal 220V cord and plug. I assume the former wire is the one I need. (I mean it seems too obviousConnecting between boiler and thermostat
- Verify the thermostat connection is OpenTherm not mains voltage!
- Decide where to install the gateway between boiler and thermostat
- Disconnect the boiler from the mains supply
- Cut the 2 core wire that connects the thermostat to the boiler
Thanks!
