EATON Homeheartbeat Controller/System
Posted: Thu Oct 26, 2006 11:21 pm
Based on Zigbee (IEEE802.15.4) from EATON HOLEC.
The Home Heartbeat System is a new and innovative way to increase your home awareness by giving you vital information about the essential systems in your home. No matter where you are the system delivers the information you want about your home, 24 hours a day, 7 days a week.
Every HomeHeartbeat system starts with three basic components:
Base Station, Home Key™ device, Sensors.
The Base Station acts as a wireless relay. It takes in information from the sensors and reports that information back out, to your Home key device when within range of the home, and to your cell phone via text messaging when you are outside of the home. Coming soon will also be a broadband gateway option - allowing you to log in to an internet page and view the status of all your sensors in real time. Whenever and however you need to be notified, home heartbeat will contact you.
The Home Key™ is a control panel for the sensors and a display device for the base station – all in one. The Home Key™ device is the only interface you need to activate your sensors. Simple pre-programmed commands on the Home Key will walk you through the entire set up process. It’s that easy.
Sensors keep the pulse of your home in check. They monitor the status of things and alert you as soon as a change occurs. Is the window open or closed? Is the basement floor wet or dry? Is the light on or off? Home Heartbeat sensors will let you know.
http://www.homeheartbeat.com
Pieter Knuvers
Pieter Knuvers
