2. control heating circuit (C2 ) setpoint2 via Home Assistant.
Posted: Mon Jun 03, 2024 4:13 pm
can anyone here give me a tip on how to control the 2nd heating circuit in Home Assistant?
I can use the OTMonitor to change the flow temperature using the “ C2= ” command.
But the service is not made available to me in Home Assistant.
Attached are pictures of the services that can be called up.
I can also retrieve data via MQTT.
Auszug von der Logging:
15:49:09.348914 T807F0000 Read-Data Slave product version: 0 0
15:49:09.675630 B407F6401 Read-Ack Slave product version: 100 1
15:49:10.352055 T80000200 Read-Data Status: 00000010 00000000
15:49:10.674293 B40000200 Read-Ack Status: 00000010 00000000
15:49:11.345072 T90010800 Write-Data Control setpoint: 8.00
15:49:11.676570 B50010800 Write-Ack Control setpoint: 8.00
15:49:12.094502 PR: I=11
15:49:12.345449 T90080800 Write-Data Control setpoint 2: 8.00
15:49:12.673864 B50080800 Write-Ack Control setpoint 2: 8.00
15:49:13.341245 T90383200 Write-Data DHW setpoint: 50.00
15:49:13.674118 B50383200 Write-Ack DHW setpoint: 50.00
15:49:14.338394 T80200000 Read-Data DHW2 temperature: 0.00
15:49:14.666083 BE0200000 Data-Inv DHW2 temperature: 0.00
15:49:15.337464 T801A0000 Read-Data DHW temperature: 0.00
15:49:15.667225 BC01A3418 Read-Ack DHW temperature: 52.09
15:49:16.339303 T80000200 Read-Data Status: 00000010 00000000
15:49:16.667722 B40000200 Read-Ack Status: 00000010 00000000
15:49:17.333598 T001B0000 Read-Data Outside temperature: 0.00
15:49:17.659806 BC01B15F8 Read-Ack Outside temperature: 21.97
15:49:18.331160 T80190000 Read-Data Boiler water temperature: 0.00
15:49:18.658366 BC0191600 Read-Ack Boiler water temperature: 22.00
15:49:19.328740 T801C0000 Read-Data Return water temperature: 0.00
15:49:19.661046 BC01C15B4 Read-Ack Return water temperature: 21.70
15:49:20.336521 T801F0000 Read-Data Flow temperature CH2: 0.00
15:49:20.655164 B401F16C8 Read-Ack Flow temperature CH2: 22.78
15:49:21.324878 T00110000 Read-Data Relative modulation level: 0.00
15:49:21.655416 BC0110000 Read-Ack Relative modulation level: 0.00
15:49:22.127305 PR: I=11
15:49:22.327334 T80000200 Read-Data Status: 00000010 00000000
15:49:22.655901 B40000200 Read-Ack Status: 00000010 00000000
15:49:23.321012 T80130000 Read-Data DHW flow rate: 0.00
15:49:23.647203 B70130000 Unk-DataId DHW flow rate: 0.00
15:49:24.319390 T001D0000 Read-Data Solar storage temperature: 0.00
15:49:24.645814 BF01D0000 Unk-DataId Solar storage temperature: 0.00
15:49:25.321902 T001E0000 Read-Data Solar collector temperature: 0.00
15:49:25.670506 BF01E0000 Unk-DataId Solar collector temperature: 0.00
15:49:26.314749 T00210000 Read-Data Exhaust temperature: 0
15:49:26.643047 BC0210021 Read-Ack Exhaust temperature: 33
15:49:27.312072 T9081100E Write-Data Message ID 129: 4110
15:49:27.639545 B5081100E Write-Ack Message ID 129: 4110
15:49:28.316329 T80000200 Read-Data Status: 00000010 00000000
15:49:28.636782 B40000200 Read-Ack Status: 00000010 00000000
15:49:29.309902 T90100400 Write-Data Room setpoint: 4.00
15:49:29.639500 B50100400 Write-Ack Room setpoint: 4.00
15:49:30.259206 T10170400 Write-Data Room Setpoint CH2: 4.00
15:49:30.633663 BD0170400 Write-Ack Room Setpoint CH2: 4.00
15:49:31.253628 T90181938 Write-Data Room temperature: 25.22
15:49:31.634838 B50181938 Write-Ack Room temperature: 25.22
15:49:32.160012 PR: I=11
15:49:32.253326 T80800000 Read-Data Message ID 128: 0
15:49:32.629320 BE0800000 Data-Inv Message ID 128: 0
15:49:33.249692 T90821D41 Write-Data Message ID 130: 7489
15:49:33.629878 B50821D41 Write-Ack Message ID 130: 7489
15:49:34.247551 T80000200 Read-Data Status: 00000010 00000000
15:49:34.630621 B40000200 Read-Ack Status: 00000010 00000000
15:49:35.245919 T90010800 Write-Data Control setpoint: 8.00
15:49:35.624746 B50010800 Write-Ack Control setpoint: 8.00
15:49:36.242958 T90080800 Write-Data Control setpoint 2: 8.00
15:49:36.627012 B50080800 Write-Ack Control setpoint 2: 8.00
15:49:37.246147 T90383200 Write-Data DHW setpoint: 50.00
15:49:37.619038 B50383200 Write-Ack DHW setpoint: 50.00
15:49:38.240678 T80200000 Read-Data DHW2 temperature: 0.00
15:49:38.616306 BE0200000 Data-Inv DHW2 temperature: 0.00
15:49:39.242880 T801A0000 Read-Data DHW temperature: 0.00
15:49:39.614499 BC01A3400 Read-Ack DHW temperature: 52.00
15:49:40.235758 T80000200 Read-Data Status: 00000010 00000000
15:49:40.617596 B40000200 Read-Ack Status: 00000010 00000000
15:49:41.232785 T001B0000 Read-Data Outside temperature: 0.00
15:49:41.652042 BC01B15F8 Read-Ack Outside temperature: 21.97
15:49:42.189851 PR: I=11
15:49:42.230863 T80190000 Read-Data Boiler water temperature: 0.00
15:49:42.611507 BC0191600 Read-Ack Boiler water temperature: 22.00
15:49:43.257728 T801C0000 Read-Data Return water temperature: 0.00
15:49:43.633190 BC01C15B4 Read-Ack Return water temperature: 21.70
15:49:44.230588 T801F0000 Read-Data Flow temperature CH2: 0.00
15:49:44.602995 BC01F16AC Read-Ack Flow temperature CH2: 22.67
15:49:45.231645 T00110000 Read-Data Relative modulation level: 0.00
15:49:45.605900 BC0110000 Read-Ack Relative modulation level: 0.00
15:49:46.255662 T80000200 Read-Data Status: 00000010 00000000
15:49:46.619931 B40000200 Read-Ack Status: 00000010 00000000
15:49:47.220316 T80130000 Read-Data DHW flow rate: 0.00
15:49:47.609972 B70130000 Unk-DataId DHW flow rate: 0.00
15:49:48.223290 T001D0000 Read-Data Solar storage temperature: 0.00
15:49:48.618683 BF01D0000 Unk-DataId Solar storage temperature: 0.00
15:49:49.217967 T001E0000 Read-Data Solar collector temperature: 0.00
15:49:49.594118 BF01E0000 Unk-DataId Solar collector temperature: 0.00
15:49:50.220133 T00210000 Read-Data Exhaust temperature: 0
15:49:50.591676 BC0210021 Read-Ack Exhaust temperature: 33
15:49:51.213251 T9081100E Write-Data Message ID 129: 4110
15:49:51.590199 B5081100E Write-Ack Message ID 129: 4110
15:49:52.220679 T80000200 Read-Data Status: 00000010 00000000
15:49:52.224864 PR: I=11
15:49:52.589634 B40000200 Read-Ack Status: 00000010 00000000
15:49:53.208457 T90100400 Write-Data Room setpoint: 4.00
15:49:53.585329 B50100400 Write-Ack Room setpoint: 4.00
15:49:54.209324 T10170400 Write-Data Room Setpoint CH2: 4.00
15:49:54.583955 BD0170400 Write-Ack Room Setpoint CH2: 4.00
15:49:55.204262 T90181938 Write-Data Room temperature: 25.22
15:49:55.581477 B50181938 Write-Ack Room temperature: 25.22
15:49:56.203438 T80800000 Read-Data Message ID 128: 0
15:49:56.579472 BE0800000 Data-Inv Message ID 128: 0
15:49:57.204047 T90821D41 Write-Data Message ID 130: 7489
15:49:57.577580 B50821D41 Write-Ack Message ID 130: 7489
15:49:58.197238 T90020004 Write-Data Master configuration: 00000000 4
15:49:58.578598 B50020004 Write-Ack Master configuration: 00000000 4
15:49:59.199495 T80000200 Read-Data Status: 00000010 00000000
15:49:59.573825 B40000200 Read-Ack Status: 00000010 00000000
15:50:00.193189 T90010800 Write-Data Control setpoint: 8.00
15:50:00.574492 B50010800 Write-Ack Control setpoint: 8.00
15:50:01.191252 T90080800 Write-Data Control setpoint 2: 8.00
15:50:01.574849 B50080800 Write-Ack Control setpoint 2: 8.00
15:50:02.193754 T90383200 Write-Data DHW setpoint: 50.00
15:50:02.250690 PR: I=11
15:50:02.566018 B50383200 Write-Ack DHW setpoint: 50.00
15:50:03.187404 T80200000 Read-Data DHW2 temperature: 0.00
15:50:03.564068 BE0200000 Data-Inv DHW2 temperature: 0.00
15:50:04.229925 T801A0000 Read-Data DHW temperature: 0.00
15:50:04.563328 BC01A3400 Read-Ack DHW temperature: 52.00
15:50:05.183609 T80000200 Read-Data Status: 00000010 00000000
15:50:05.564570 B40000200 Read-Ack Status: 00000010 00000000
15:50:06.180605 T001B0000 Read-Data Outside temperature: 0.00
15:50:06.557852 BC01B15DC Read-Ack Outside temperature: 21.86
15:50:07.178146 T80190000 Read-Data Boiler water temperature: 0.00
15:50:07.559229 BC0191600 Read-Ack Boiler water temperature: 22.00
15:50:08.178338 T801C0000 Read-Data Return water temperature: 0.00
15:50:08.554448 BC01C15B4 Read-Ack Return water temperature: 21.70
15:50:09.174634 T801F0000 Read-Data Flow temperature CH2: 0.00
15:50:09.554697 BC01F169C Read-Ack Flow temperature CH2: 22.61
15:50:10.173395 T00110000 Read-Data Relative modulation level: 0.00
15:50:10.550578 BC0110000 Read-Ack Relative modulation level: 0.00
15:50:11.170696 T80000200 Read-Data Status: 00000010 00000000
15:50:11.548297 B40000200 Read-Ack Status: 00000010 00000000
15:50:12.122467 T80130000 Read-Data DHW flow rate: 0.00
15:50:12.289546 PR: I=11
15:50:12.413036 B70130000 Unk-DataId DHW flow rate: 0.00
