I bought 3 off these LED lights to replace my existing Halogen Lights in the bathroom.
This should be a real quality LED light, I will report back when they are burning price 29,95 a piece.
Bulb
3W LED LIGHT BULB
Base
GU10 Twisted Bi-Pin
LED Count
1 x 3W CREE Q5 XR-E
Light Output White
WHITE 240 Lumens
Installation Class
Plug & Play
Beam Angle Bulb
60 degrees
Light Source
Solid State White LED Lamp Dice
Body Materials
Die Cast Aluminium
Life Time
50,000 Hours
Front Protection
Glass Optical Lens
Voltage
110-240V
Wattage
3W
Color Temperature
5,500 7,000 Kelvin
DIMENSIONS
Maximum Overall Length (MOL)
2.28 in ( 68 mm)
Bulb Diameter (DIA)
1.97 in (50 mm)
Base Bi-Pin
0.394 in (10 mm)
Special Features
Light Dimmable Switches Not workable
GU10 3W Q5 Cree LED 240 Lumen daylight
Moderator: Mversluis
Looks good
I have also done some replacement..and will do more in net next months.
This evening a got a newsletter from German led shop
they have interesting leds.
http://www.del-ko.de/
Checked them out and ordered some LEDs too for replacement:
1 x 9 Super SMD LED Leuchtmittel G4 Warm Weiss (Lieferdauer: sofort) D-G4-S-9-WW 11,99 EUR 11,99 EUR
1 x 12 SMD LED Strahler MR16 - 120 Superhell - Warm Weiss lieferdauer: sofort) D-MR16-12SMD-WW 11,95 EUR 11,95 EUR
1 x 24 SMD LED Strahler MR16 Warm Weiss (Lieferdauer: sofort) D-MR16-24SMD-WW 13,95 EUR 13,95 EUR
1 x LED Leuchtmittel G4 Sternenhimmel Weiss (Lieferdauer: sofort) D-G4-1-W 2,49 EUR 2,49 EUR
1 x LED Leuchtmittel G4 Sternenhimmel Warm Weiss (Lieferdauer: sofort) D-G4-1-WW 2,99 EUR 2,99 EUR
1 x 6 LED Sensorlicht mit integriertem Bewegungsmelder EUR 9,95
1 x 25 LED Einbauleuchte Warm Weiss (Lieferdauer: sofort) D-EL-25-WW 9,95 EUR 9,95 EUR
Will get back on the results!
I have 5 of this..
.only problem is the power adapter consumption is so low that they will not burn.
minimum is about 30 watt
I'm going to use standard 12v 1A adapters hoop that that will help.
Also 2 of this.
http://www.beleuchtung-mit-led.de/produ ... Weiss.html
Also 2 of this.
Hi Pieter and Enver,
We have also this kind of lights , like GU10 and Mr16 even much more.
On the moment we are busy with G4 replacement light , the will be expeted about 3 weeks ( 10 different kind off light , to test )
best regards,
Marco
best regards,
Marco
Pieter, what's your take on those lamps you tested?
Are they "approved" or not?
not received yet, keep you posted!
