Today I changed the energy consuming standard Harrisons Adapters for the switched "Dehner 12volt 500ma 6 watt" power supply.
I measured the power consumed when opening and closing the curtains.
In my case it was 3.5 watts, so this small new adapter can do the job.
In idle position, so if the motor is not used the Adapter is consuming < 1 watt, I can't measure it.
The standard power adapter is using idle 3 to 4 watts.
I have 6 rails so again around 16 watts reduction.
The Dehner (Sunny) switched adapter is costing Euro 8.99 at www.conrad.nl
http://www.conrad.nl/goto.php?artikel=510819
There is a post about it on the forum, but can't find it.
