newbie plugwise install
Posted: Wed Dec 03, 2008 10:27 pm
by Ruud
I am installing plugwise right now.
But circle + is ok , but i don't see de other plugs.
Is this not automated or must i do this by hand?
Ruud
Posted: Wed Dec 03, 2008 10:30 pm
by Snelvuur
when you install the program, you should see the other ones..
what i did is just stick them all together, and then in a power socket.. pretty funny because you can hear them switch on, then the next one , etc etc..
Posted: Wed Dec 03, 2008 10:48 pm
by Ruud
how long dit it take to see all the circle's
Gr Ruud
Posted: Wed Dec 03, 2008 11:19 pm
by TANE
This depends on location and other RF systems
+/- 15 min...if not you can reset them and try again.
Posted: Wed Dec 03, 2008 11:27 pm
by DJF3
Yeah, make sure the other ones are pretty close. At least in the beginning. Then you can start moving them around to see if they keep their connection. If you have a larger distance between 2 plugs (for example one in the attic and one on the ground floor) you might have to put one in the 'middle'.
Nice suggestion Snelvuur! Never thought about that.
bye
DJ
Posted: Wed Dec 03, 2008 11:31 pm
by Ruud
I have all circle nr entered in de configmenu.
Now i am waiting in the "select moduled menu" to see of the circle's come online. is that de right procedure?
ruud
Posted: Wed Dec 03, 2008 11:32 pm
by TANE
Yes
after 15 min..your must see them all...else reset the plugs that your don't see online.
Posted: Wed Dec 03, 2008 11:50 pm
by Ruud
45 min later no plugs alone the circle+ and the stick.
And the al the plugs are only 1 meter away from de + and the stick
[:(] ruud
Posted: Thu Dec 04, 2008 9:14 am
by Ruud
Pffff calling the "helpdesk"
After reset off al plugs no result.
Only the circle + is responding
Ruud
Posted: Thu Dec 04, 2008 10:51 am
by wwolkers
are the plugs working? as in if you put a lamp in one of the plugs, will it go on?
you should also be able to hear a 'click' when the plug turns on or off.
Posted: Thu Dec 04, 2008 10:12 pm
by Ruud
I'm happy plugs are working!!!!! reset (not waiting for the klick)
was the solution. Now the next step, let it work with homeseer.
Gr Ruud
