Pronto Edit v 2.1.18
Posted: Thu Feb 19, 2009 6:39 pm
by Bastiaan
The new version Pronto Edit supports 64bit. Since I am runing mainly 64bit that was nice to see. If I download the file from the Philips website I get a corrupt version.
Did anybody managed to get the program decently unzipped?
If so, please update the file section with it too.
Posted: Thu Feb 19, 2009 7:38 pm
by Snelvuur
Try the files section under "Pronto/PEP"
Posted: Thu Feb 19, 2009 7:59 pm
by Bastiaan
Hi Erik,
Think you did not read the message good enough or I was not clear:
The PEP file here on the server has a date stamp of November, the Philips one came out in December. It might be a good idee to add the version in the filename, (as Philips does).
Bastiaan
Posted: Thu Feb 19, 2009 8:00 pm
by Snelvuur
http://files.binkey.nl/Pronto/PEP/Pront ... 2_1_18.zip
after you posted your message, i did just that.. i think you still need to do F5 (refresh)..
Posted: Thu Feb 19, 2009 8:02 pm
by Bastiaan
Can't keep up with your speed
(What's in the name)
Did you unzip it as test?
Txs a lot!
Posted: Thu Feb 19, 2009 8:04 pm
by Bastiaan
This one unzipps without a hitch.
May be good idee to add the latest 6.xxx firmware update too?
Posted: Thu Feb 19, 2009 9:37 pm
Thanks Erik.
Do you have the latest firmware also?
Posted: Thu Feb 19, 2009 9:59 pm
by Snelvuur
Well i normally just download these things from remotecentral or philips site and then i just upload them..
but i added 9400 & 9600 firmware to it.
Posted: Fri Feb 20, 2009 7:35 am
by Bastiaan
V2.1.18 does not run on Windows 7 x64, not even in compatibility mode
It starts but I run in all sorts of problems, no loading of the DB's, gallery import hangs or stops etc.
Did anybody test it on Vistax64?
