We are using the BWR102 for a while now, but it's measurements are very poor...
If I try to measure my weight and do this 10 times in a row, I get lot's of different measurements with an offset of 1 kg.
Do you also experience this ??
Thanks,
BWR102 offset...
BWR102 offset...
No problems here with the BWR102.
10 times is giving the same result.
- Antoon
<h6>
- Antoon
<h6>
BWR102 offset...
Same here, do you use a solid underground?
BWR102 offset...
When using the BWR102 in the living room I'm 2.0 kg heavier then in the bathroom.
- Snelvuur
BWR102 offset...
the further you are away from the center point of the earth, the lighter you are. So you must way less in the 30th floor then on the ground floor.. (in theory that is)
BWR102 offset...
I would use it in the bathroom then [:)]
Btw.. I don't have that problem with the BWR102..
Maarten Damen
www.maartendamen.com
Maarten Damen
- Jeroen Bartels
BWR102 offset...
May scale always has an offset of 12 kg.....(higher that is
I went to the shop who sold it to me and he told me to loose weight..
Jeroen
Jeroen
- Snelvuur
BWR102 offset...
As long as you stand on it and it does not say "1 at a time please" you should be ok
BWR102 offset...
I believe only one of the 4 feet that the scale is standing is is actually being used to measure your weight.
So if you are standing on the scale a little off-center the measured weight may vary also.
And for those where the scale is displaying weights that are way too high, consider mounting an electronic lock on the freezer so that it only opens when your weight is below a certain value ...
