Replacing an RFXMeter sensor - keeping the same address?
Posted: Tue Apr 21, 2009 11:30 pm
I had an RFXMeter with 2x RFXPwr and 1x RFXPulse.
One of the RFXPower sensors has been replaced by an RFXPulse.
- The 'new' RFXPulse now has the same 'address' as the old RFXPower module, is that Ok?
This new RFXPulse module is used to monitor water. This works fine. I have changed the RFX configuration to "RFXWater" and changed the 'divide by' from 1000 to 1.
To monitor the daily water usage I would like to add a Virtual device.
- I cannot see the DWAT[xxx]d device when adding a virtual device in the RFXCOM HS plugin (version 13.x). Do I need to do something specific? (or any tips?)
<b>UPDATE:</b> The new 'water' items are still stored in the Power table of the RFXCOM database. That means that even though I renamed the device to "RFXWater" it's not detected as a Water device. Screenshot:
Thanks!
DJ
Thanks!
DJ
