All,
Was looking to get a cable tester, but i just want a simple tester which you can hook up to 1 wire, and then on the other end have something which beeps or lights up if you have the right wire.
Most all these devices are usb testers/upt testers/cat5/cat6/coax, but it does not say just 1 single wire.
You guys have a website with a nice device for this? (i just want a done deal solution, dont want to build something)
Thanks
Cable tester
Cable tester
I think you are looking for a "kabel tracer"
Example:
http://www.eleshop.nl/va-kabel-tracer-p-210.html
Maarten Damen
www.maartendamen.com
Example:
Maarten Damen
- Snelvuur
Cable tester
that sounds about right, i'll give it a try. merci
- Snelvuur
Cable tester
Even better then i wanted it to be! Since the electrician just have like loads of cable sticking out in 1 of my rooms, i dont know where everything goes. I can just hook 1 end in some room and i only have to wave it like a magic wand on the cables down below and it will make a sound (and will increase sound) if i go towards the right cable.
Excellent way to search a cable.
