Marmitek EasyIcon 10RF
http://www.intellihome.be/userFiles/ima ... RF.jpg.jpg
New remote from Marmitek.
Is able to controll all house and unit codes mixed!
http://www.intellihome.be/nederlands/mu ... rmitek_x10
New remote control from Marmitek: de Easy Icon10 RF
Marmitek says:
De Easy Icon10 RFTM has a HF transmitter to combine with Marmitek infrared systems like the ControlAnywhere.
Operate your A/V equipment and X-10 modules throughout the house
The most user-friendly remote control ever. The only one you will ever need.
Choose a channel using the well known, network logos. You no longer need to remember which channels your favourite networks are on.
Personalise the remote control for each member of the family - fixed favourite channels for you, your partner, children and even (grand) parents and the babysitter (up to 10 users).
Guaranteed to work with all you current and any other A/V equipment you purchase in the future (extremely comprehensive pre-programming with learning facility).
In addition to 10 A/V devices (TV, decoder, DVD, set-top box etc.), you can also operate the Marmitek X-10 modules used for operating lighting and electrical appliances.
With handy home theatre macro function: with 1 press of a button you can switch all your equipment and X-10 lighting to the correct setting.
It can be used for X.10 and it is compatible with ActiveHome en ActiveHomePro. Uniek aan deze X-10 controller is dat alle Housecodes door elkaar gebruikt kunnen worden.
09837 Easy Icon10 RF
Consumenten adviesprijs (incl. BTW) 80 euro
http://www.marmitek.com/en/index_consum ... roduct=476
GRTZ, Verkenner
Marmitek says:
GRTZ, Verkenner
Does anybody have any experience with this remote together with Homeseer?
Funny as the button layout is exact the same as this one wich i got some where in june and was on sale at the aldi for 20,- but mine IR only and not connectable to a pc. ( manual does not mention anything about it )
http://images.google.nl/imgres?imgurl=h ... G%26um%3D1
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by AshaiRey</i>
<br />Does anybody have any experience with this remote together with Homeseer?
I am using this remote for a few weeks now and also have homeseer.
I use a few TM13's around the house to receive the RF x-10 signals from the remote and the SS13's I have. You can make configurations for every room you have and select icon's to te buttons that genereate the x-10 signal. Works very well!
Thanks for the update
Can some of you telling me of this remote has a timer in it?
It works also with KlikAanKlikUit systems?
Thanks.
Thanks.
Please let me know if this remote has a timer inside.
I like to buy this one, but the timer is an important issue for me.
Thanks all.
Thanks all.
The remote has sleeptimer fuctions for every device.
It can be set to 15, 30 45 60 or 90 minutes.
With the macro function you can set delays from 1 to 10 seconds.
You are saying that I can't multiply sleeptimer functions to 24 hours?
You use them for your TV or audio.
When you want timers at pre defined times, it is better to use the CM15Pro computer module.
With the ActiveHomePro software you can make timers for every X-10 device you have.
You can also make macro's and start them with your remote. The CM15Pro can work standalone after you have downloaded your settings to it.
So no need for a PC 24 Hour a day, like with homeseer.
You can download the software at the Marmitek site and evaluate it without a CM15Pro to see if it can do what you want before you buy the CM15Pro.
@Wim2008
What are you trying to accomplish with the timer(s)?
The timer is only for controlling my lights in the living. The lights have to on when it is getting dark and have to out if it is 23.00 houres.
Futher I like to combine my remote controll for tv and audio with the remote controll TMT-502 from KAKU (with timer).
If this is possible, I like to replace that to with this Easy Icon10RFTM.
Have bought the remote, will test this weekend... will let you know.
See also post http://www.domoticaforum.eu/topic.asp?TOPIC_ID=3370
Hi Eric J,
Where did you get the remote and what was price?
