is it possible to control velux "dakramen" with rfxcomm
Posted: Tue Jul 07, 2009 6:51 pm
by Edwin2008
I have two Velux "dakramen" which are controlled electrically via a remote. Is it possible to replace the remote with rfxcomm or supplement the remote.
At this time the windows shut automatically when it starts raining but i also would like to open them when it gets to hot and partially close them when wind is picking up.
Posted: Tue Jul 07, 2009 7:00 pm
by Snelvuur
as far as i know there not supported by rfxcom, there are some other options which are pricey.
See http://www.domoticaforum.eu/topic.asp?TOPIC_ID=1680
Posted: Tue Jul 07, 2009 7:34 pm
by Edwin2008
yes i'm aware of them :) but was hoping to do it via rfxcomm
Posted: Tue Jul 07, 2009 10:03 pm
No for sure not supported by rfxcom.
Posted: Tue Jul 07, 2009 10:07 pm
by Fantic
When you have a spare remote, you could use the ippower mod like Chak has shown in one of the other posts and control the windows using the 'buttons' of the remote itself. Main problem I always found with the Velux solution is they can be closed by rain, but never return to the previous position when the rain stops. By connecting them to Domotica you overcome this problem. Just add a window contact and see when they close and use a rain sensor to tell the system when it's raining.
Regards, Maarten.
Posted: Tue Jul 07, 2009 11:06 pm
by Edwin2008
I was looking for a solution without "abusing" a remote
Posted: Thu Jul 09, 2009 1:03 pm
by Droezel
Ive had that problem too, you'll have to use the Velux KUX-100, a Velux KLF-100 and some other module that gives open/closed contact like the KAKU SUN-500 wich is controllable by RFXCom.
Posted: Thu Jul 09, 2009 8:30 pm
by Lempens
When you have the older motor of Velux, you can use IRDA
Posted: Thu Jul 09, 2009 8:50 pm
by Edwin2008
no it is a rf one :(
Posted: Fri Jul 10, 2009 9:28 am
by Lempens
The have a normal switch which you can place on a wall KLI 110 WW
http://www.velux.nl/nl-NL/all_lists/Doc ... 6-2009.pdf Maybe you can use it.
Posted: Fri Jul 10, 2009 9:51 am
by Edwin2008
On page 22 i see a io-homecontrol adapter and an interface but i'm not sure if HS can communicate with them.
Posted: Fri Jul 10, 2009 5:10 pm
by Lempens
I have found
http://www.domoticafourm.eu/uploaded/Le ... F20100.pdf
  • <li>potential free switches </li><li>Compatible with products with the io-homecontrol logo
    Based on radio frequency (RF) technology, 868 MHz range </li>
    <b>Download Attachment:</b> [img]images/icon_paperclip.gif[/img] KLF20100.pdf<br />103.63 KB
Posted: Fri Jul 10, 2009 7:25 pm
by Edwin2008
perhaps a solution, luckely i only have two windows
