Merten CONNECT radio Argus 220 (509519)
Posted: Fri Aug 28, 2009 11:36 am
Merten has a new zwave enabled movement sensor in its catalogue. It concerns the Merten CONNECT radio-Argus 220 (509519). The documentation mentions that up to four radio ARGUS 220 CONNECT devices can be networked and set via the remote control (permanent ON, permanent OFF, automatic, brightness threshold, switching time, set and change the sensitivity to movement.) and that in conjunction with the CONNECT radio configuration tool, you can fully integrate the radio ARGUS 200 CONNECT into the radio network and network with other devices.
It's not clear to me if this device can send zwave status signals to a central control box in order to launch an action. It seems to me that the zwave functionality only supports remote control of the sensor itself. Can anybody clarify this?
Pieter
Pieter
