RGB Controler 20 euro
Moderator: Mversluis
Last week in the Conrad mailing.
nice controller wit option for IR and USB
http://www.conrad.nl/goto.php?artikel=181818
USB interface 15 euro
IR interface 6 euro.
- Jeroen Bartels
When buying 10 pieces they cost not 20 but 15 euro (-25%). Stupid question: I don't need changing light effects but I want to be able to set the color of the led's to a warm color and switch it on/of. Is this the product I need? I also feel that the prices for the RGB led's are quite expensive at Conrad. Where to buy good led's for good price?
Jeroen
Jeroen
I also only need one...and already ordered.
I'm almost sure that this device can be controlled via Homeseer. Using the script that Esteban has build
IR will always work..if you have Irtrans or any other IR sender.
For the color led strip you can better look somewhere else.
I have my strip via Marco
meter price is 30 euro
http://www.mood-ledlight.nl/index.php/L ... p-RGB.html
I have already the Chromoflex version. for this device I need some extra hardware for controlling via Hoemseer. (USB >RS232)
The price of chromoflex is much higher.
And the most importend , our products are better [:D][:D][:D]
30 euro per meter? pdf says for 5 meter.
Alexander
Alexander
@Marco
Reclame aan het maken?
Ruud
Ruud
@Mgizmo The price is not clearly on the site. But I think it's 30,- p/meter
learningpoint for Marco [;)]
Joomla has a bug and can not be set to a value like
- meter
- real
- piece
- etc
So the price would be 30 euro each meter.
But when the domoticaforum is buying more reals in one time , I can make a discount for ou all
- meter
- real
- piece
- etc
@Enver,
Just recieved today a other IR controller from my supplier , this one is "a litte box"
The size is about 4 x4x 4 cm , with a separate IR reciever and a credit card model IR remote.
The Remote has 24 buttons, each color has his one button.
So it would be very easy to controll this from the domotica system , without any difficults with sliders etc.
Just give it a try and provide me feedback ( i should bring one when we leaving to the "jaarbeurs" )
Ciao Marco
Ciao Marco
I think its still to expensive. I would need +- 12 meter. That would cost me at most EUR 360,- If the price would be EUR 150 i still would not buy it. I really want the systems in different rooms, but i would rather buy multiple touch screens than this pricerate for LED's.
So i was hoping the 5 meter in the PDF was correct for that price. I do understand the reals is 5 meter and can be cut every meter. I've to wait
Alexander
Alexander
@Alexander
Touch screen will not give any light,..
I have the RGB and warm with in the living room.
For my desk I use about 1 meter warm with.
Price for this was including power adapter 20 euro.
Power consumption is 5 watt
for 20 euro you will not find any good alternative.
I replaced my old Ikea desk light what was using 20 watt
my saving is 40KW (10euro) per year
Led looks much better and less space.
@Marco
my hope is that the Conrad controller will work fine..if not i can still use the IR what is build in this controller.
specs of you new controller looks good..I still need some other controlling options for other rooms..YES I like to test it.
Can this kind of controllers also be used for dimming single color leds?
@Marco
Is there any RGB controller, besides the DMX LAN box, that should be able to control from within Homeseer without using IR? For instance using USB or serial?
Controller in the first post can do that
Cost are 35 euro including USB adapter
We only need a nice plugin...
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rklootwijk</i>
<br />Is there any RGB controller, besides the DMX LAN box, that should be able to control from within Homeseer without using IR? For instance using USB or serial?
http://www.samenkopen.net/action/196205
Alexander
Alexander
