ChromoFlex III RC - USB Dongle Problem
Posted: Fri Dec 25, 2009 4:33 pm
Hello to all,
About a 8 months ago we purchased a Chromoflex III RC controller with an RC Remote and USB Dongle. The setup is now installed in our kitchen (after laying for 7.5 months in the corner not being used).
The result is absolutely stunning. (I'll try if i can upload some pics here).
In the last 0.5 year i sometimes played with the CF3 and USB dongle, all works fine. Last week i attached the USB dongle for the first time to my Win7
Pro machine and start 'playing' again
later that day i want to switch off the RC3 via the standard "Color Editor Software" but i ran into some problems.
(later tested under XP pro, same story as above. and it always has worked under this version before)
Every time i start de Color Editor software i get the following error, "No USB Interface found" after some 'investigation' it looks that my usb dongle
is reseted or cleared (or just broken
). The USB dongle uses the FTDI F232R chip-set, with some software (MProg.exe) from the FTDI company you
can readout/re-program the F232R chip-set.
When i take a look @ the field 'Product Description' it now says "USB Serial Converter" (this description can also be found when looking via the
Windows Device Manager -> Universal Serial Bus controllers -> USB Serial Converter or Chromoflex). That's a strange point because the color editor
software is only looking for devices with an product description called "Chromoflex". So based on the above info the the error message "No USB Interface found" is valid.
My questions to you guys (and girls off course),
PS.
Thank you for your time and effort, and a Merry Christmas to everybody.
- - Are there any users present with an CF3 and USB Dongle?
- If there are any users with the USB dongle, can and are you willing to provide me some info about the used driver(settings)?
- Has anybody heard before about this 'strange' problem(s)?
- Anybody ideas the reset, check, test the USB Dongle?
- Does anybody know if there are Firmware upgrades/downloads available for: the USB Dongle / CF3 Controller?
- Other questions, points to discuss or information?
PS.
- I'm already in contact with Barthelme about this problem, but i thought why not ask you guys also.
I'll try to attach some screen shots of the MProg software and the Windows Device Manager to clear some things up.
For users who want to use the MProg.exe software... be carefull, make sure you first use the "Read and Parse" (via the Tools menu) option
so you can use the "Save As" option to make a copy of your current FTDI device settings. (this tool allows you to upload (default?) settings also, brick up you device?)
