Network problem
Posted: Fri Mar 26, 2010 11:45 pm
by phoenixb
I have a strange thing, when i connect my HS server directly to my Linksys WRT54G router or EFAH05W 10/100 hub then i getting a low upload/dowload speed on my HS server (even for local use) but when i connect a simple Asus 10/100 5 port hub then the upload speed is going must better.
What can be the problem, because this extra HUB is not so good for my energy performance ;-)
Grtz,
Re: Network problem
Posted: Sat Mar 27, 2010 3:03 am
by Alexander
DJ,
First: I will reply to your e-mails this weekend. Sorry for not letting know earlier.
Second: Read this article (http://en.wikipedia.org/wiki/Autonegotiation), especially the "Duplex mismatch" part. That is properly the cause of your problem.
Re: Network problem
Posted: Mon Mar 29, 2010 1:58 pm
by phoenixb
In the first place i think also this is the problem, but the router settings give me the following settings:
Auto-Negotiate: Yes
100 Mbit: Yes
Full-Duplex: Yes
and on the PC:
Link Speed/ Duples Mode: Auto Negotiation
I think this is ok, but i have 1 issue the router is 10/100 and the pc 10/100/1000 can be the probem that de pc whant to work on 1gb?
Grtz,
Re: Network problem
Posted: Mon Mar 29, 2010 2:21 pm
by Rene
Just disable autonegotiation at both sides. Autonegotiation is often the cause of these kind of problems. For 1Gbps connection it is required to enable autonegotiation.
Re: Network problem
Posted: Mon Mar 29, 2010 7:30 pm
by phoenixb
Thanks it working not without a extra hub ;-)
