Ik krijg een error als ik op de interface tab klik,iemand een idee waar dit door komt?
bedankt edwin
Server Error in '/' Application.
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Source Error:
Line 303: <%
Line 304: For i As Integer = 9 To 12
Line 305: Dim DevInfo As Specialized.StringDictionary = garrDevices.Item(i)
Line 306: Dim strClass As String = IIf((i And 1) = 1, "tableroweven", "tablerowodd")
Line 307: %>
Source File: C:\Program Files\HomeSeer HSPRO\html\RFXCOM\RFXCOM.aspx Line: 305
Stack Trace:
[ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index]
System.Collections.ArrayList.get_Item(Int32 index) +7485640
ASP.rfxcom_rfxcom_aspx.__Renderpnl2io(HtmlTextWriter __w, Control parameterContainer) in C:\Program Files\HomeSeer HSPRO\html\RFXCOM\RFXCOM.aspx:305
System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +88
System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +25
System.Web.UI.WebControls.WebControl.RenderContents(HtmlTextWriter writer) +10
System.Web.UI.WebControls.WebControl.Render(HtmlTextWriter writer) +32
System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +52
System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +198
System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +27
System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +189
System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) +167
System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) +32
System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) +221
System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) +47
ASP.rfxcom_rfxcom_aspx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) in C:\Program Files\HomeSeer HSPRO\html\RFXCOM\RFXCOM.aspx:25
System.Web.UI.Page.Render(HtmlTextWriter writer) +30
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +4849
Version Information: Microsoft .NET Framework Version:2.0.50727.3603; ASP.NET Version:2.0.50727.3082
error on main page
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
