Page 1 of 2
UM7206 reponding on other device
Posted: Mon Apr 19, 2010 9:23 pm
by Herbus
I have an UM7206 (http://www.marmitek.com/nl/catalogus/pr ... product=27) that's responding on the switch of an other device. When I switch a nearby lamp (normal switch, no X10-device!), the UM7206 is sometimes accidentally switching.
It seems that it’s responding on power ON/OFF switching of an other 220V/AC device (in this case a lamp). Does anybody knows the cause or better: a solution?
I need a A10/X10 device with a (“potentiaal vrij”) contact. Are there alternative A10/X10 devices?
Thanks for your help and suggestions……
Re: UM7206 reponding on other device
Posted: Mon Apr 19, 2010 9:38 pm
by drmacchi
What are your settings ? Continuos or momentary ? did you try to change the wall outlet?
Posted: Mon Apr 19, 2010 9:48 pm
by Herbus
It's switching continuous. So when I give a X10 command ON it’s ON, when I give a command OFF it stays OFF.
In other outlets it’s acting the same way and is responding on other switching devices.
Posted: Mon Apr 19, 2010 10:03 pm
by drmacchi
If you change housecode , does it react anyway?
Posted: Mon Apr 19, 2010 11:23 pm
by Herbus
Changing the housecode doesn't solve the problem.
Posted: Tue Apr 20, 2010 8:25 am
by esschenk
I think you have a defect one
Mine is working now for more then 1 year and never had this strange effect (modifyd us Model)
Ed
Posted: Tue Apr 20, 2010 9:18 am
by drmacchi
I agree with Ed, if out of range (housecode changed) it should never react.Ciao !
Posted: Tue May 18, 2010 8:31 pm
by Herbus
Just installed a new UM7206. Same problem. Switching the light switch nearby (1,5 mtrs) causes the UM7206 to switch itself.
Looks like the switch is putting a spike (noise) on the powerline.
Does anybody now a way to filter this noise (anti noise capacitor???)
Thanks,
Jos
Posted: Wed May 19, 2010 11:14 am
by DJF3
For the 'potentiaal vrij' solution, what would yu have to buy?
Posted: Wed May 19, 2010 3:28 pm
by Henk
Use an on/off X10 actor and add a 230V relay to it ...... you may have to increase the load with a resistor or so .... or alternative use a transfomer and add a low voltage relay
Henk
Posted: Thu May 20, 2010 11:15 am
by Herbus
Did some Googling on this subject.
The "spike" (noise) is caused by the switch. It seems that the UM7206 is sensitive for this.
Solution sould be found in using a Snubber: http://en.wikipedia.org/wiki/Snubber
Conrad has a combined component (resistor + capacitor) for this: http://www2.conrad.nl/goto.php?artikel=452335
Gonna order a couple of these and will test if this is a solution.
Posted: Sun Jan 22, 2012 10:13 pm
by bartbakels
Hi Herbus,
I Have the same issue with an UM7206, I use it to open a gate. It shares its powersupply with the controlunit for the motors, Sometimes when i close or open the gate my UM switches, without asking. The weird thng is taht only the relay switches, but the beeper not. I can switch it off and on by my x10 controler without problems.
Do you have the solutiom? Filtering? Does the snubber solves your issue? If so please let me know
Thanks
B Bakels
Posted: Sun Jan 22, 2012 11:08 pm
by Herbus
Yes, the snubber from Conrad solved my problem. No problems at all after installing this simple device in the switches.
Posted: Sun Jan 22, 2012 11:12 pm
by bartbakels
Great Jos,
Thanks, I will order a couple of them ;) Btw how do u install them? Conneting to L and N? Do they do the same as the X10 filtermodules?
thanks for the help
Posted: Sun Jan 22, 2012 11:24 pm
by Herbus
Pfff I don't remember. I think they are mounted over the contact from the switch. Please search internet, because I'm not sure. Or order an extra couple :-)
