Can I extend an existing wisselschakeling with an AWMR-230?
Posted: Tue Jun 08, 2010 2:04 pm
by emklap
I want to extend and existing wisselschakeling/hotelschakeling with an additional remote controlled switch.
I am thinking of using an AWMR-230 in combination with a WST-8800 switch in the following manner.
- AWMR_230_wissel.jpg (13.07 KiB) Viewed 15558 times
With this configuration, can anyone tell me if I can do the following
Preconditions: Light is turned off.
1) Turn the light ON using switch A
2) Then turn the light OFF using the WST-8800
3) Turn the light back ON using switch B
4) and turn the light back OFF using switch A
Is this possible?
Re: Can I extend an existing wisselschakeling with an AWMR-230?
Posted: Tue Jun 08, 2010 5:09 pm
by PietjeNL
Think its possible but probably u need to put the AWMR-230 on the fase and the wire that goes directly to the light.
This cause AWMR-230 has only 2 wires that u can connect, but normally it does still respond on the normal switch, only now u will have 2 switches.
Posted: Tue Jun 08, 2010 8:19 pm
by Fantic
Maybe this could solve youre situation it did for me:
- Puls switches to turn the light on/off
- Hotel puls.jpg (3.24 KiB) Viewed 15540 times
The Xanura SAIX12 will accept switched and puls signals to change it's state. With only 1 switching wire you can switch at many different locations.
You might want to see oif a similar KAKU unit is available.
Posted: Tue Jun 08, 2010 9:06 pm
by emklap
Thanks for all your responses.
I also looked at the SAIX12 but I could not find a X10 remote conreoler that I can screw ON to the wall (like the WST-8800)
I could connect the SAIX12 in the following manner if I had a remote control like the WST-8800.
- Saix12_wisselschakeling.jpg (36.62 KiB) Viewed 15532 times
Unfortunately there is no possiblilty to add the 3rd switch wired, and the ceiling is more than 4.5 high so also a remote switch in the ceiling is not an option.
Posted: Tue Jun 08, 2010 9:19 pm
by PietjeNL
Then its cheaper to just swap to all KAKU switches and 1 reciever.
Posted: Wed Jun 09, 2010 9:23 am
by emklap
KUKU switches dont fit into my GIRA wired electrical system.
I have not looked at the GIRA range of remote products', but they are mostly very expensive
The remote control type 2251 112 cost around 108 euro alone.
a switch costs 65 to 100 Euro
Posted: Tue Aug 03, 2010 1:48 pm
by eDsuB
emklap wrote:Hi,
Is this possible?
Based on the documentation of the AWMR-230 it is only possible to use that particular KaKu switch with a simple 9enkelvoudige) wall switch.
I think this has to do with the fact that the AWMR-230 uses only the Live and the Switch wires to connect to the specific terminals. (no neutral used). With a Hotelschakeling ths Live and Switch 'signals' vary between the wires depending on the state of each switch.
Posted: Sat Jan 07, 2012 3:19 pm
by DJF3
Interesting discussion... Question remains...
Has anyone been able to use a single KAKU AMWR-230 in a "hotel schakeling"?
- Don't want to use any X10 device
If this is absolutely not possible I'll use this scenario:
- AMWR-230 at the bottom of the stairs
- AWST-8800 (wall switch) at the top of the stairs (placing it on top of the removed 'normal' switch)
Cheers
DJ
