http://www.mrsoft.fi/ohj01en.htm
It is called Logtemp and can be installed on a Windows machine.
Reads all Dallas 1-wire sensors and can produce charts, exported as JPG,
write to file like HTML, RSS, SQL-database or Excel.
This program is running on my Homeseer server for a week now and everything seems ok.
Integration with Homeseer can be done by scripting or SQL.
Great 1-wire software found!
Re: Great 1-wire software found!
And xAPMenno wrote: Integration with Homeseer can be done by scripting or SQL.
I am working on SQL script, it is not finished.
Scripting on a reading of html page is also possible.
I have finished my script, it is straightforward and does not check for false readings. (if a sensor does not read out correctly).
For this script to work, you must have device's S1 to Sxxx these devices represent your 1-wire devices. For convenience, i added a script that creates your devices.
Look into the script 'sql1wire' and modify your 1-wire adresses.
- scripts.rar
- (1.12 KiB) Downloaded 1150 times
