I use my tv with the command line app remco.exe wich is part of the Fenestra package.
source is on the jointspace forum.
Philips TV jointSPACE support?
Moderator: RDNZL
Re: Philips TV jointSPACE support?
Where did you get the "remco.exe" because I cannot find it.r_255 wrote:I use my tv with the command line app remco.exe wich is part of the Fenestra package.
I've downloaded the "Fenestra-2011_11_08-Debug.zip" but there is no "remco.exe" inside.
Do you know if this works with 2010 TV models?
Frank
Hey Frank,
Its been a while... so i might be confused. Remco.exe has to be compiled from the source.
Fenestra debug package looks different as i dont see any sources in that.
I will have a look when i am at home and report back later on.
Okay i was wrong, it is in the win32 sdk
http://sourceforge.net/projects/jointsp ... z/download
Compile it in visual studio on a 32bits windows machine and you there you have remco.exe
This should work on a 2010 model as mine is
Last weekend I read about JSTx and got it to work on my Raspberry Pi.. NICE!
However...
Now everything is working I have no clue on what I really want to send to my TV??
- "Doorbell ring"? (I can obviously hear that?)
- "New email"? (that will generate > 30 messages an hour?)
- don't have phone integration (people call my cell)
- Webcam images (on doorbell ring)? Can't do it because they generate JPG's and TV needs PNG's.
What do I want to send to my TV?
Any ideas?
However...
Any ideas?
when youre favorite program on channel xx is starting
there are some interesting examples on a german forum using JSTx : [ip-symcon.de/forum/threads/11705-Philip ... nden/page9]. For example: show the doorbell on the ring is one thing you can do. You can use a linux tool like Imagemagick to convert the image from JPG to PNG and then show it on the screen:
e.g. "jpegtopnm img.jpg | pnmscale 0.5 | pnmtopng >/tmp/test.png"
Hi all
I would like to send messages to my philips from hs2 or hs3 windows based. Any progress on that? Do looking for a windows commanlinetool eith a send message capability.
Regards
Bart
Regards
Bart
(ON ESXI )on NUC
(ON ESXI )on NUC
