plug stops responding (SOLVED)
Posted: Thu Sep 23, 2010 6:05 pm
by Edwin2008
suddenly one of the plugs stops responding. Source and firmware already updated and the plug is showing the latest firmware BUT i canĂ½ control the plug from the source or HS. Also the plug is not tranmitting any date (does not show current use)
I tried a plug reset but i'm not really shure about the correct procedure. Am i correct that a plug reset is the last thing to try before caontacting plugwise support?
edit.
You just won't believe it. After 1 week not responding the plug suddenly went alive, almost right after i posted. I think it got scared
Re: plug stops responding (SOLVED)
Posted: Thu Sep 23, 2010 9:12 pm
Strange..... but good its running again
Which firmware are u running now?
Posted: Thu Sep 23, 2010 10:17 pm
by PietjeNL
Pm'ed him, problem is solved, plug is online again.
Maybe plug out of reach or something blocking the signal.
Posted: Fri Sep 24, 2010 8:55 am
by Edwin2008
I'm running latest source & firmware (2.15(20100328.0 / 2009-09-08). Plug was only 3 meters away from the other plug's (for the firmware update last week) and only 1 meter away from the stick.
But as said, somehow it suddenly worked again like it should.
Posted: Fri Sep 24, 2010 3:36 pm
Ok so the new firmware 2.29 is still not available from Plugwise I see.
I'm running it in Beta for a while now together with source 2.16
Posted: Fri Sep 24, 2010 4:54 pm
by Edwin2008
Hm? Did they change the format of the firmware string? Source was something like 2.xx and the firmware looked like a date string.
Posted: Fri Sep 24, 2010 5:01 pm
OK my firmware is from 27-4-2010 and is called 2.29 but I guess its not visible in the source.
Posted: Fri Sep 24, 2010 5:04 pm
by Edwin2008
i got my firmware info from a screen in the source (nstellingen/apparaten) left screen and then scroll to the right.
