Converting an USB 1141 into serial
Posted: Sun Oct 03, 2010 12:52 pm
by Willem4ever
Anyone has a picture of the inside of a PLCBUS 1141 serial adapter ? I see it is prepared for a DB 9 connector, but there is also another free spot on the PCB, need to you know if there is anything else I have to do to convert a USB into Serial. The USB version is giving me a headache since al the lastest profile drivers incl. 64 bit ones do not seem to work.
Cheers, Willem.
Re: Converting an USB 1141 into serial
Posted: Wed Oct 06, 2010 10:51 am
by letitbe
I found this German description:
http://www.plc-bus.info/viewtopic.php?f=19&t=4
I think you can ask for English support.
Posted: Wed Oct 06, 2010 8:44 pm
by Willem4ever
thanks !
Posted: Thu Oct 07, 2010 12:37 am
by JohnieBraaf
Too bad, you need an external 5V power supply for this modification.
That makes it more or less only useful, when no USB is available.
Posted: Thu Oct 07, 2010 10:45 pm
Some people (including me) still have a dislike of USB and the drivers that you need to use.
Posted: Thu Oct 07, 2010 11:57 pm
by Mdamen
JohnieBraaf wrote:Too bad, you need an external 5V power supply for this modification.
You could use USB to get the 5v power..
Posted: Fri Oct 08, 2010 7:25 am
by Willem4ever
Digit wrote:Some people (including me) still have a dislike of USB and the drivers that you need to use.
Yep especially with this unit, the latest profilic drivers are not working and you have to refer to an old driver. It is that my wife likes the crystal switches otherwise I would toss it out completely.
Posted: Fri Oct 08, 2010 7:26 am
by Willem4ever
I have 5 volts available in the wiring closet so not really an issue
