best software to use with Rfxcom
Posted: Fri Mar 04, 2011 8:39 pm
by francisb
Several years ago i bought a reciever and some sensors for energy and gas registration. It is all setup and running for a couple of years now, but i never found the time to write or buy some software to use with the hardware.
Now i have some little time and i was wondering what the best choise of software is for the use of the rfxcom hardware.
Most of you readers and writers have the best experience with all of the domotica stuff, what do you people recommend?
Best regards,
Francis
Re: best software to use with Rfxcom
Posted: Fri Mar 04, 2011 8:48 pm
by CRaZee
I'm using homeseer with the rfxplugin and rfxcharts.
Just to get a system up and running very quickly.
Posted: Sat Mar 05, 2011 2:32 pm
by francisb
Ok, but is there not a program that at least puts the data from rfxcom in a (preferable) Microsoft sql database. From there i can present the data into graphics.
cheers,
Francis
Posted: Sat Mar 05, 2011 7:48 pm
by CRaZee
Hi Francis
I am looking for something like that too.
I don't have time at this point to build something myself.
That's why i got homeseer to get my domoticasystem going.
Chris
Posted: Sat Mar 05, 2011 10:25 pm
Make a script or something that puts the data also in every database you want. You can trigger that if the device changes. I think there are enough samples on the Internet available.
Posted: Sun Mar 06, 2011 1:37 pm
by b_weijenberg
If you want a ready made system select Homeseer with RFXCharts. This solution is using a MS-Access database and creates selectable charts.
Or use xPLRFX or DomotiGa for logging of the decoded received data, create a script to store this data in a database and write charting software
Posted: Wed Jan 18, 2012 3:27 pm
by labium
i have never used a rfxchart yet in homeseer, is the userguide of rfxcom in homeseer the right source for how to ?
Posted: Wed Jan 18, 2012 3:36 pm
by b_weijenberg
RFXCharts is developed by Paul.
The RFXCharts plug-in and Installation guide is here: http://www.jphuddlestone.co.uk/rfxcharts/rfxcharts1.htm
In this thread you will find additional information about RFXCharts usage and installation http://board.homeseer.com/showthread.php?t=128902
Support on RFXCharts is done by Paul.
