Yes, but it has to be done in the sketch I guess.
I assume you search the bus for 1-Wire devices, put them in an array and loop through that array to get the temperatures?
What you could do is re-arrange that array with addresses in the order you want. This would probably mean hard-coded addresses inside the sketch, which is not very good in terms of maintenance (what happens if you replace a broken sensor... change the sketch? That's NOT good...)
Why do you want to influence the order anyway? Just curious....
Jeenode+DS18B20+Homeseer
Moderator: Mdamen
Re: Jeenode+DS18B20+Homeseer
The array is a great idea indeed.
The reason i want to influence the order is because i want to measure the temperature (ingoing /outgoing) of my 7 floorheating groups.
It would be convenient to order the devices according the groups (in/out next to eachother). I think cabling would be much easier.
I'm thinking of one 'bus' cable with connectors (RJ11?) for the sensors.
