Dimmable Lights - HELP
Posted: Tue Dec 18, 2007 5:27 pm
I need to start "finishing" my ceilings - still have just a couple of lamps hanging from temporary sockets.
The issues are:
1) I do want to have dimming capabilities (preferably compatible with regular X10 dimming modules.)
2) Incandescent lamps are going to be banned soon (2009 in Ireland, a few years later in the US - and I suppose all other countries will do the same sooner or later) - so, incadescent lamps are defintely not an option. (I don't know if halogen lamps are included in this banning)
So, what other sorts of lamps, currently available and dimmable, would you suggest using for a new project?
I've heard there are compatible LED controllers, that can transform regular "dimming" AC voltages to LED light levels, but don't know if they are common.
I suspect that kind of controllers will become more common in the future, but my wife is not willing to live much longer with those "temporary lamps" that have been there for 2 years already.
So... HELP?
<b>Edit:</b>
Just apropriately, just after writing this post I came across an old "Circuit Cellar Magazine - August 2007" where Steve Ciarcia (one of the people responsible for me to be interested in Home Automation) wrote about the current lighting situation.
His conclusions were:
1) LED lights have a wide range of efficiencies and configurations. Current units have 50lm/W while higher efficiency ones are nearly 100 lm/W.
2) There are no current LED lamps that can match a 60W incandescent bulb. LED spotlights can be compared to 45-50W regular lamp, brightest nondirectional LED lamps are similar to 25W bulb.
3) LED lamps don't like dimmers. Dimmers need a minimum resistive load to work properly. Because most led lamps are under 10W and many have reactive-capacitive loads, TRIAC's go crazy.
4) Traditional X10 modules also don't work well with LED lamps. Some may turn on, many will not turn off. The trickle current to sense manual lamp control will cause the LED to flash. (Don't know if this applies to our European models)
So... are we stuck with having to wait for enhanced LED lamps/controllers to show up?
It shouldn't be too hard for manufacturers to make a "dimmer" compatible controler embedded into the Led Lamps - it would be far simpler than the CFL electronic ballasts.
The issues are:
So... HELP?
<b>Edit:</b>
