in my new house i installed 3 watermeters from aquatel, wich have a pulse connector.
Normally the reed contact is open (no connection), but when the magnet passes the reedcontact closes.(connection) (and could stay closed when the meter stops on the magnet).
I tried connecting this sensor between the ds2423 A connector and the +5V. But i get strange readouts...
So i went looking, and it seems when I connect the A connector with 5V i get an incement of the counter(so thats ok), but more than one (seems to be related to the time it's connected.)
Does anyone have a solution for this problem ( or a working schema?)
Thanks!
water meter and ds2423 problem
Re: water meter and ds2423 problem
It seems like you need some sort of circuit to make a neat pulse from the watermeter output. Even when the meter stops on the switch you want a short pulse. This can be achieved by using a Monostable Multivibrator like 74LS221 IC. I have used this one for my gas and watermeter. Unfortunatly I do not have a schematic, because it was made on a sunday afternoon on a breadboard. Read the datasheet carefully and with some experience on electronics you must be able to make a circuit.
this sounds like a solution! however, my experience on electronics isn't so great.... so i am not so sure what circuitry i need around it...
can anyone help with a scematic?
