Does anyone know if it's possible to made a connection (only for the video) to connect it to a pc or a other device that can convert video to Ethernet? from this doorcam -> Alecto DVM 91
Grtz,
Alceto DVM 91 doorcam
Moderator: Esteban
__________________
Re: Alceto DVM 91 doorcam
Take a videoserver this is one of the cheapest
http://www.pimzos.nl/shop/aviosys/ipvid ... nector.php
Ed
Ed
not possible Ed, this is a wireless camera
Sorry this is a rtfm
ed
ed
Not exactly a solution, but it should be possible:
I've heard of it being done with cheap (cabled) video doorbells that send everything over two wires, although I have never seen it working myself. Although wireless, the video signal and 'ringing button' signal, from this doorbell, is sent (from the outdoor part) via a wire to the green connector connection (which supposedly also provides power to the camera) inside, before being converted into a wireless signal (by the indoor part).
So the video is in there somewhere and probably it is using pretty low-level tech. The trick is figuring out how to extract a composite(?)coaxial(?) video signal out of those two wires that you can pipe through an IP video encoder.
That said some other cam solution might be more cost/time effective.
Thanks for the tips, i think that this is not really the solution.
I will search for a other solution
Grtz,
Grtz,
__________________
