I wonder if clicking 'run now' in an event will evaluate a condition or not.
Is it right to assume a condition needs to evaluate to true in order to make the event run?
Any experience?
Thanks
OWK
Events: 'run now' evaluates condition?
Moderator: RDNZL
Domotiga
Cubietruck, Ubuntu server 1.0.2
RFXcom LAN, home brew ground plane antenna
KaKu
KaKu
Re: Events: 'run now' evaluates condition?
Run now will run without the conditions config'ed
Alexander
Ok, thanks.
In case a condition is evaluated (when the event is processed normally) it needs to be true to allow to start event processing?
Olaf
Olaf
Domotiga
KaKu
KaKu
Yup, that's how it works hereOWK wrote:Ok, thanks.
Olaf
ie: Dev_53_Value="Disarm"
Eval result: True
Event is processed.
