Chromoflex RGB LED HomeSeer PlugIn
Moderator: Digit
If anyone is interested in controlling LED lights via an RGB driver you might want to take a look at a free plugin I have just released for this purpose.
See here:
http://board.homeseer.com/showthread.ph ... ost1001006
NicolaiL
See here:
NicolaiL
Re: Chromoflex RGB LED HomeSeer PlugIn
Congratz, I'm sure a couple of people will be more than happy to test this
(I can't as I don't have access to my CF at the moment)
This is a good start of the new year...
setting id and colors work fine here :O)
great stuff !!!
great stuff !!!
Thanks guys, your support is very encouraging.
I think I mentioned in the manual that is part of the package hosted on the HS forum that it has been tested with the Chromoflex Standard controller. This one here: http://www.chromoflex.com/html/chromofl ... ndard.html
I don't think the RC version of the Chromoflex controller doesn't have a serial port so it wouldn't work with these.
Generally, for RGB led projects this one:
Chromoflex Standard Stripe”: 3*2.5 Ampere, 7.5-24 Volts, for LED Stripes
http://chromoflex.com/html/chromoflex__standard.html
No experience with this shop, but 41.8 eur including shipping:
http://www.led-shop24.de/led-strips-led ... 000050.htm
Thanks for this plug in, works like a charm!
Hi, this is a very useful and nice plugin.
Is it also to use with the Chromoflex RC Version ??
Regards, Fischi
Regards, Fischi
I`m using this plugin for quite some time now and would like to migrate to HS3. Will there be a HS3 version available ?
I've the same question, will there be a HS3 version?
