Nemef Radaris Evolution Plugin
Alles m.b.t. de Nemef Radaris Evolution plugin van Robert Hekkers (DUTCH forum)
Moderator: Digit
Re: Nemef Radaris Evolution Plugin
@peter:
So, where will we be discussing this further .. my weblog, this forum or email as I suggested somewhere.
Pick just 1 please, cause that's the maximum amount of input channels per subject I can handle right now.
but its better to wait until i have my answer from nemef
they will check your list i hope, i think i have a mail 2morrow about that
plugin is hs2 i think, but its Roberts apartment :)
Right, HS2 only at the moment.
Hi Peter
I sent you a mail, but not sure ig you got it?
Peterpc
Post by Peterpc »
Wednesday they are going to install the radaris door lock.
Where can I find the HS2 plugin?
Peter
http://www.pcgsm.nl/
Not on this forum, that's for sure :)
The last time I did something with it must have been around summer of 2012 so I'll have to see if it still compiles ... ; it already was in a stage where it was ready to be tested so you'll be "the chosen one" for that :wink:
I think I can release it without much effort but the things to do in the weekend are piling up already so it might take some more time. But I think I should be able to let you have the Plugin before the lock itself is operational.
Peterpc
Post by Peterpc »
Hi Robert,
Ok, and thanks for all the good work!
Peter
Peterpc
Post by Peterpc »
Hi Robert,
Installed the files,
activated the plugin
Go to http://localhost/NemefRE/NemefRE.aspx
and get this error:
Parser Error Message: The file '/NemefRE/CCPanel.ascx' does not exist.
Am I missing this file, or do I have to create it? (update: file is added to the zip)
Please advice.
Peter
Peterpc
Post by Peterpc »
I have connected the RF interface.
It is a USB interface and seen by the computer as a com port.
It is com port 8
At "general" I have selected serial and com port 8 and saved it
When I go to "RF modules" and select "ADD" nothing happens and no module is added.
It says all modules are configured, but there is no module visible.
Please advice.
Peter
Peter,
To speed things up a bit (13 hours have passed between you posting & me reading) it's better to mail me @ home.
The Plugin has only been tested very briefly with serial so a lot of things can still go wrong.
After adding the Module the next thing you'll have to do is add a controller as well ("the door lock", cause a single Module can control up to 4 Controllers IIRC).
Only after that the Plugin will start "collecting" badge Id's which are being used, so that you can add them, name them and so forth.
For now:
When I click "Add" I get his:
After a 2nd "Add" click I get his:
Is this the same as what you're seeing?
Awaiting your response (including a debug log @ highest level if not...) at my home email address; just pick an obvious one :)
Return to “Homeseer Nemef Radaris Evolution plugin Forum”
