home made 1-wire temp sensor won't work
Forum about 1-Wire devices.
thespriteman
Post by thespriteman »
Hi there,
i tried to create an 1-wire temprature sensor using the following scheme:
and now i tried it using LogTemp (http://www.mrsoft.fi/ohj01en.htm)
but it keeps telling me: "1-Wire network does not exist"
how can i troubleshoot this?
[Edit 19-05-2012 23:52]
after some testing and searching i got it working with this scheme:
With Regards,
technofreak
Re: home made 1-wire temp sensor won't work
Post by technofreak »
You can use this circuit as 1 Wire to RS232 Interface.
I can provide you the PCB files if you plan to make your own..
Schematic - RS232 1Wire Hub
xpowayout
Post by xpowayout »
is it possible to connect the 1-wire devices from hobby-boards.com to the RFXsensor and use the value in HS?
raza
Return to “1-Wire Forum”
