Domation Mono Led and Homeseer
Moderator: Mversluis
Snelvuur
Re: Domation Mono Led and Homeseer
Post by Snelvuur »
Not bad.. always nice to place it in the kitchen :)
Rebel
Post by Rebel »
Nice modules, I have 2 RGB in the kitchen, 3 RGB and 2 mono modules in the living.
It works perfect with the provided scripts. Both with Homseer and HS Touch!
Grtz,
Arjo
labium
Post by labium »
what kind of plugin is being used for these leds, the link provided doesnt tell anything about the integration in homeseer. Monoled stays quite misty that way.
Moskus
Post by Moskus »
I'd also love some more information around this, and it's integration in HomeSeer. :)
HSPro 2.5.0.60, X10 CM11, Z-wave Aeon Stick2, RFXCOM, Script Connector, BT connector, DI Connector, DooNetwork, HSTouch, Squeezebox plugin, iTach WF2IR & GC-100-6 with UltraGCIR, BLicon, DenonAVR, WebcamXP, Jon00s MaxiBee and Webpage builder
mrtiger
Post by mrtiger »
Not much info about the hardware.....
Sorry for the late response.
Some info:
Domation products are works on 868mhz
In Domation network you can add 255 devices
Every device can be controlled individuel or all at once.
Every Led drive can control up to 3 mono strips or one RGB strip (7A)
Current PC interface is USB (FTDI) RS232 on request
The PC interface will also be usable in the future for other Domation products. (Remote RS232, Remote I/O. ARFID, RFID)
Current Homeseer integration is based on HS scripting.
Homeseer Create script will build the HS devices that can control the led strips.
More info about the Homeseer scripts
http://tane.nl/shop/domation/homeseer/
Vera scripts are in the make.
HomeSeer mono devices.png (41.27 KiB) Viewed 23854 times
HomeSeer RGB.png (25.7 KiB) Viewed 23854 times
Moskus
Post by Moskus »
Very, very interessting. Do you ship to Norway?
please contact me by mail..
as MR. Homeseer I hope you van optimise the script a bit more or a plugin...:)
Moskus
Post by Moskus »
TANE wrote:please contact me by mail..
I was thinkink about a plugin, actually. ;)
But first to have another look at the scripts, it would be cool to have a slider for each of the RGB values.
I'll just have to decide if I can justify the cost... I'll send you an email.
Plugin will be great..
as you cab see in the scripts commands are very basic.
I will contact you by mail..
mrtiger
Post by mrtiger »
Is there enough light in them too use them outside?
Moskus
Post by Moskus »
mrtiger wrote:Is there enough light in them too use them outside?
That really depends on what light you connect and how much light you require, as long as you only use 12V leds.
mrtiger
Post by mrtiger »
Where and how can i buy it?
Moskus
Post by Moskus »
