Page 1 of 2
Homeseer RFXCOM plug-in
Posted: Mon Feb 11, 2008 11:22 am
by b_weijenberg
De RFXCOM plugin voor Homeseer is beschikbaar op http://www.rfxcom.com/downloads.htm
Vereisten:
- Homeseer versie 2.2.0.66 of hoger.
- De 310MHz ontvanger moet versie 32 of hoger hebben,
- De 433.92MHz X10 ontvanger moet versie 21 of hoger hebben,
- De ontvanger voor Visonic sensors moet versie 8C of hoger hebben.
- Alle transmitter versies kunnen gebruikt worden.
Posted: Mon Feb 11, 2008 10:53 pm
by TANE
Bert,
Gefeliciteerd met je fantastische Homeseer plugin.
Posted: Mon Feb 11, 2008 10:55 pm
This is a great plugin for Homeseer and the Homeseer users
I examined the plugin and it's a real must have for those who use the RFXCOM products and Homeseer. (English by eception)
<h3>Description</h3>The RFXCOM plug-in enables the connection of the RFXCOM transmitter and/or RFXCOM receivers into Homeseer.
By means of the RFXCOM plug-in, the RFXCOM transmitter can control:
KlikOn-KlikOff, ELRO AB600, NEXA, Flamingo and Domia Lite modules,
X10 lighting modules and the X10 security panel,
Harrison electrical curtains.
The RFXCOM plug-in is able to receive sensor and remote data from:
X10 lighting and security sensors and remotes,
Oregon Scientific sensors,
KlikOn-KlikOff remotes, wall-switches and chimes,
Visonic/SecureLinq PowerCode sensors and CodeSecure remotes,
ATI Remote Wonder,
RFXSensor,
RFXMeter with RFXPulse and RFXPwr modules.
<h3>Requirements</h3>Homeseer 2 with at least version 2.2.0.66,
All versions of Microsoft .NET Framework installed, (1.1, 2.0, 3.0 and 3.5)
An USB or Ethernet connected RFXCOM receiver,
Or an USB or Ethernet connected RFXCOM transmitter.
Here some screenshots:
Pieter Knuvers
Posted: Mon Feb 11, 2008 11:00 pm
by Snelvuur
Ziet er mooi uit bert, denk dat er weer wat fans bij het clubje komen.
Posted: Mon Feb 11, 2008 11:09 pm
by TANE
en natuurlijk ook wat leuke charts
Posted: Mon Feb 11, 2008 11:41 pm
He Chak
The Weighwatcher is working for you :-)
For now!
Posted: Tue Feb 12, 2008 12:00 am
by TANE
That's not my weight..
I think it's the scale of my neighbors..[:D]
Posted: Tue Feb 12, 2008 12:07 am
Then it could be my weight, are the sensors that good :-)
Posted: Tue Feb 12, 2008 8:30 pm
by gb1980
I've tried a few packages, but I think I will go with homeseer from now on.
As I can see the text on the rfxcom site:
Plug-in requirements:
- The plug-in needs Homeseer version 2.2.0.66 or higher.
- The 310MHz receiver must have version 32 or up,
- the 433.92MHz X10receiver must have version 21 or up,
- the receivers for Visonic sensors must have version 8C or up.
I don't think this is going to work, due to the lower visonic version?
Version request to receiver => F020
4D1D538B Version Master=1D Slave=8B
Master =X10 receiver, slave is visonic
Is there an easy way to upgrade the firmware, Or is it tricky to break it?
Within homeseer loggin it also says:
Type: RFXCOM
(RexRxChar) Warning: receiver didn't respond with 2C, retry
(RexRxChar) Error: reveiver #2 didn't respond corretly to the init cmd.
(RexRxChar) Error: receiver on Com0 not used!
(but I don't use com0 on the pc, just com3 for the reveiver, and com4 as transmitter)
At the moment, I don't get anything in the logging from the master or the slave rfxcom.
Posted: Tue Feb 12, 2008 9:00 pm
by b_weijenberg
Your receiver versions are not supported by the plug-in and you need to upgrade them.
http://www.rfxcom.com/receivers.htm#update
Or use the ACRF2 plug-in.
Bert
Posted: Wed Feb 13, 2008 9:26 pm
by glabbeek
Bert gefeliciteerd!
Prachtige plugin voor Homeseer. Ik heb hem nu ruim een maand kunnen proberen en ik kan niets anders zeggen dat dit de missende link is die Homeseer in Europa had.
Ook je ondersteuning en input is indrukwekkend snel en duidelijk!
Vooral het gebruiksvriendelijk maken van de transmitter functies zorgt ervoor dat de RFXCOM versie handiger is dan de ACRF2 plugin.
Zoals zo velen ben ik aan het rommelen met de verschillende charting software. Om de WAF hoog te houden kan ik er op dit moment alleen niet genoeg tijd in steken.
Willem-bram
HS 2.0 / JvCADDX / SKYPE connector / RFXCOM / Moony / Mainlobby
Posted: Mon Feb 18, 2008 12:06 am
by wegdom
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by glabbeek</i>
<br />Bert gefeliciteerd!
Willem-bram
Posted: Wed Mar 19, 2008 4:06 pm
by b_weijenberg
De RFXCOM plug-in ondersteunt ook de Harrison electrische gordijnrail.
In de bijlage wordt uitgelegd hoe aan de gordijnrail een adres kan worden toegekend.
<b>Download Attachment:</b> [img]images/icon_paperclip.gif[/img] Instellen Harrison.pdf<br />27.18 KB
Posted: Mon Mar 31, 2008 6:03 pm
by b_weijenberg
Versie 6.0.0.5 van de RFXCOM plug-in is beschikbaar in de Homeseer Updater.
Input Sensor High-Low warning-alarm toegevoegd,
Configuratiepagina's voor input sensors uitgebried,
ontvangst van AC remotes & sensors (HomeEasy/KlikAan-KlikUit) toegevoegd,
path voor humidity icons gewijzigd,
hspi.RFXCOM function GetLastMessage gewijzigd in GetLastAlarmMessage,
hspi.RFXCOM function GetLastSensorMessage toegevoegd,
Alarm Panel display DeviceValue wordt opgehoogd bij een nieuw bericht. Hier kan dus een trigger op gezet worden,
Water chart gecorrigeerd,
SMS scripts toegevoegd,
Sensor Message Panel toegevoegd.
Belangrijk: maak Input Device 1 vrij voordat je het Sensor Message Panel activeert op de Input Device configuratie pagina. Het Sensor Message panel maakt vast gebruik van Input device 1. Wijs een nieuw adres toe aan sensor 1 en wijzig het sensor nummer ook in de database als de sensor een chart functie heeft.
Posted: Mon Mar 31, 2008 7:08 pm
by snowboarder
Hallo Bert,
Er zitten nog een paar kleine foutjes in de water chart
er staat overal m3 in plaats van liters.
Marcel
www.myhomecontrol.nl
