Negative (Watt) values in Source
Posted: Mon Aug 27, 2012 6:24 pm
by Redbull
I have seen some topic about negative Watt values in PHP.
However 2 of my Circles give a negative value (most of the time, but sometimes they are OK) so the total amount of current kW is not correct in Source. I tried to place them on different locations and different equipment, but still the values given are negative :-(
Does anyone has this same problem or has a solution towards it?
Btw, the firmware of the circles is from date 27-06-2011 and Source version 2.22 attached is the consumprion as in Source
Re: Negative (Watt) values in Source
Posted: Tue Aug 28, 2012 11:51 am
by nico_gh2
I also have negative values occasionally. Not the same plugin and not continous.
Besides that I find that Source needs a restart every week or so as the webserver responses get very slow, at least the browser is very slow (not) responding to clicks. After a restart of Source things are OK for a while.
Also using latest Source 2.22.
